Old 08-11-2010, 11:13 AM   #1
marcsRX
68 C10 SWB
marcsRX's Avatar
Lots of work to do.
Ordered sooo much crap.
Cant wait till it all gets here!!!
ECE Order
71-72 C-10 2.5 DROP SPINDLES
63-72 1.5" DROP FRONT COIL SPRINGS (SB)
63-72 6" DROP REAR COIL SPRINGS
KYB GR-2 FRONT DROP SHOCK
KYB GR-2 REAR DROP SHOCK
63-72 SHOCK MOUNT RELOCATOR KIT
65-72 SUPER TRACK BAR KIT
71-72 C-10 4/6 DROP KIT
63-72 POLYGRAPHITE SWAY BAR BUSHING SET
(1 1/16")
63-70 UPPER BALL JOINT
63-70 LOWER BALL JOINT
63-72 UPPER A-ARM SHAFT
63-72 LOWER A-ARM SHAFT
65-70 INNER TIE ROD END
65-70 OUTER TIE ROD END
65-70 TIE ROD ADJ. SLEEVE
68-72 PITTMAN ARM- POWER STEERING
67-82 IDLER ARM
68 C-10 FRONT END REBUILD KIT
(FOR USE w/ 800 SERIES P. STEERING)
71-72 R/H BRAKE CALIPER W/ PADS
71-72 L/H BRAKE CALIPER W/ PADS
71-72 C-10 5 LUG 12" FRONT BRAKE ROTOR
(CROSS-DRILLED LEFT SIDE)
(CROSS-DRILLED RIGHT SIDE)
71-72 DISC BRAKE PROPORTIONING VALVE
63-72 POWER MASTER CYLINDER
63-72 POWER BRAKE BOOSTER ASSEMBLY
71-72 BRAIDED STAINLES HOSE KIT
63-70 INNER WHEEL BEARING
63-70 OUTER WHEEL BEARING
63-70 INNER GREASE SEAL
WHEEL BEARING KIT
71-72 INNER/OUTER WHEEL BRG SET W/SEALS
68-72 POWER STEERING GEARBOX (2WD)
Jegs Order
Painless Performance Products #764-80300
Universal 3-Prong Sealed Beam Headlight Plugs, 2/pkg.
Painless Performance Products #764-10206
67-72 GMC/Chevy Pickup 2/4WD Custom Wiring Harness
Just for the hell of it, here are the pictures all of you have probably seen a 1/2million times.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 08-11-2010, 11:26 AM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Lots of work to do.
I think you're ECE's customer of the month!
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 08-11-2010, 11:28 AM   #3
marcsRX
68 C10 SWB
marcsRX's Avatar
If the truck doesn't ride, steer, and brake like new, I'm selling it.
Old 08-11-2010, 08:29 PM   #4
swierker
swierker's Avatar
I hope you ordered all your ECE stuff as package deals. I got just about everything you did but I only had to order about 4-5 "kits" to get it all.
I'm still waiting on my drop spindles, shock mount relocator and the proportioning valve to replace the damaged one I received.
They should be here any day now...and then the work starts.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 08-12-2010, 11:02 AM   #5
marcsRX
68 C10 SWB
marcsRX's Avatar
Yeah, I think it is a "front end rebuild kit" "4/6 Drop Kit" and then misc other stuff.
Old 08-02-2014, 08:50 PM   #6
marcsRX
68 C10 SWB
marcsRX's Avatar
Well after MANY years and a whole lot of work...
Here is how she sits and whats been done:
Installed everything listed above but have yet to do the front sway bar.
Had a 72 Cheyenne LWB that was useless but for some donor parts listed below.
Corvette rallys
New Tires
New gorilla acorn black lug nuts
Rebuilt rear drums and A LOT of brake tuning to get pedal and stopping power dialed in.
Trimmed bump stops (Helps with ride as after drop I only had about 3" of suspension travel. Now I have 4.5ish hahaha)
Alignment
Installed rear end out of donor 72 which is POSI but needs rebuild
Used front LCAs from same donor 72 which has provisions for sway bar from factory
Painted/POR15 various suspension/brake components.
New battery
New starter
New correct heads with steam holes for SB 400 motor(Engine came out of a 73 Caprice)
Plug wires and plugs
New alternator
New water pump
New exhaust and Sanderson headers
New transmission output shaft seal
Installed spot light from donor 72 which was some kind of forest ranger truck
Installed black tilt column from donor 72
Old 08-02-2014, 09:16 PM   #7
jeh
jeh's Avatar
Looks good, that's a lot of new parts!!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 08-02-2014, 09:37 PM   #8
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Yeah. Lots of work. But look what you have now!!!
Very nice.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-02-2014, 09:51 PM   #9
marcsRX
68 C10 SWB
marcsRX's Avatar
Thanx guys. Winter project will be 200 R4 and rear end rebuild.
Old 08-03-2014, 11:59 AM   #10
R.L.
R.L.'s Avatar
that's a great looking truck, congratulations.
R.L. is offline   Reply With Quote
