08-11-2010, 01:54 PM | #1 |
Under Construction
anyone running a LOKAR eliminator gas pedal setup
i was wanting to see if anyone has installed a Lokar eliminator setup. if you have , i would like to see pictures.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
09-03-2010, 02:33 PM | #2 |
Re: anyone running a LOKAR eliminator gas pedal setup
ttt. I would like to see this as well.
09-03-2010, 02:46 PM | #3 |
1970 C10 six
What is it?
1970 C10 L6 250 three speeder |
09-03-2010, 03:13 PM | #4 |
Under Construction
its a gas pedal but the cable runs from the floorboard rather than the firewall....
http://www.customrodder.com/tech/050.../photo_10.html
09-03-2010, 03:26 PM | #5 |
PROJECT 7DEUCE
What pics would you like to see I have installed 2 of them on in the 72 and one in the 56..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-03-2010, 03:30 PM | #6 |
Under Construction
I would like to see where you mounted on the '72, inside and outside shots would be grand. I have the regular lokar on my '56 but trying to stay away from the firewall on my sons '67. I was planning on drilling holes in the corners of the mark for the center square a little larger then using a jigsaw to finish cutting the square.... lil nervous and dont want to mess up ... what did you use to cut the square ?
Thanks for your time!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 09-03-2010 at 03:32 PM. |
09-03-2010, 08:52 PM | #7 |
Active Member
I have a Lokar elminator pedal in my 68 and really dislike it
They could have made a few small changes to the way the pedal mounts and made it much easier I also lose some throtle speed due to cable movement with the long sweeping cable. I am kicking around the idea of going to a 71-72 set up or one of the direct fit pedals that feeds thru the firewall All that being said I have a friend that builds street rods for a living and installs these pedals into any car he can - loves tucking everything doen low and hidden
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
09-03-2010, 10:02 PM | #8 | |
Under Construction
Thanks for your comments.
09-04-2010, 12:59 PM | #9 |
PROJECT 7DEUCE
Heres a few crappy cell shots on mine........
09-04-2010, 01:48 PM | #10 |
1970 C10 six
So what is the advantage? Pedals a pedal right?
09-04-2010, 01:52 PM | #11 |
PROJECT 7DEUCE
Its just a little cleaner on the top.. Ill get some digital photos here ina little bit..............
09-04-2010, 02:26 PM | #12 |
Anybody have a part number for this item? How much is it?
Thanks! |
09-04-2010, 02:27 PM | #13 |
PROJECT 7DEUCE
09-04-2010, 03:36 PM | #14 |
Old Skool Club
It's one of the parts I have stashed, along with the cables and other items.
To install it, you have to cut a hole in the floor and mount it to the floor. The cables attach to the back side of the pedal. My reason to get one for my truck is the original ball-stud mount for the OEM pedal is not any good. One of the studs broke off and the new floor pan didn't have any. I know the studs are available. I just wanted something different and clean.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-04-2010, 07:45 PM | #15 |
Active Member
Something to think about with your floor pan - if your truck is like mine with a partial floor pan replacement you will find 2 floors or layers of sheetmetal in the area that you mount this pedal - in my case I could work around it with longer bolts, just be aware going forward
If the space is to deep between the two layers of sheet metal it will hinder the ability of the lever to stick through the floor and may affect the over all travel of the lever
09-04-2010, 09:01 PM | #16 |
Old Skool Club
09-05-2010, 11:26 AM | #17 |
Under Construction
thanks for the info. I have the setup in my parts pile... just gathering additional info etc., before i attempt the install.
09-05-2010, 01:10 PM | #18 |
I used the later swinging pedal with cable in my '67 and it has worked perfectly since day-one. I think it is basically the same pedal/swing arm from '71 up into the '80s trucks. The really nice thing about using the stock GM parts is that you can get the cable from any car or truck of the era. They made that same cable in many dozens of different lengths.
I grabbed several from cars and trucks at the wrecking yard and the one I used was from a Cad. I am seldom impressed with Lokar installations. On the cables themselves, spending $100 on a cable and not spending any time or real thought on the mounting brackets is a waste. It isn't going to function any better than if you had pulled a cable off an old lawn mower. I'll let Chevy do my engineering before Lokar any time. A cable with pedal engineered as part of it should have taken care one end, but 1968SWBBigBlock didn't sound like he was very impressed with it. I should caution that putting a Chevy swing pedal in, is a lot easier when the engine is out. The old holes can be welded closed from outside much easier.
'67 GMC 2500, 292, 4spd, AC |
