GM made with FORD paint
I have a birthday coming up next month and i was wondering what the best lowering kit there is for the money. I was thinking about a 2.5 drop in the front and a 4 in the rear. i want to go low as i can go without Notching the frame.
I also would like to see pics of trucks with the same stance. Looking forward to the responses.
1972 GMC Custom 1500, 2WD LWB, 1970 chevy impala SS 350 c.i., shaved door handles, Ford Paint (portofino blue), blue underglow, and much more. 1998 GMC Sierra 1500 ext. cab, 2WD SWB, 305 c.i. all original 165,000 miles and still strong (daily driver) |
Man of Mini-Talents
Re: Best lowering Kit that wont break the bank
Quantify "break the bank"
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
under a grand if possible
A blow torch is cheap!...kidding
I would think that getting some drop springs and some drop blocks for the rear would accomplish that with some new shocks for way under a grand (I think I saw a for sale posting from some drop springs on sale at gmcpauls where it was 96/pair for 2.5'' drop springs (maybe another site, could be wrong)). I would think that if you were dilligent enough, getting that drop for under 500 would be possible if you just went with springs and blocks. Could be wrong. I also would like to see some pics ![]()
Have mercy, I'm recovering from my 4x4 addiction. ![]() |
Man of Mini-Talents
Go to www.earlyclassic.com
You can get a complete kit with all the parts to get it done right for a lot less than your budget. Happy birthday!!
Senior Moment
![]() Join Date: Mar 2002
X2 on Early Classics. Quality parts
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
I got this kit (with 3" front/5" back drop springs...specify when you order what drop you want) for $599. I have no complaints so far. Made a world of difference in handling.
http://www.classicperform.com/Store/...k/6572LHPK.htm
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Man of Mini-Talents
By the way, 4/6 seems to be the lowest usable without a c-notch.
Any issues with a 4.5" front drop?
Looking for a short fleetside bed in the Pacnorthwest/western Canada. |
Senior Moment
I forgot about CCP. I've used there stuff before, Good Quality there too
Man of Mini-Talents
Given a reasonable tire size, no.
My response was in regards to a c-notch. The lower you go, the more factors come into play. Spend a few hours on the suspension forum, or better yet, call a forum vendor and tell them what you want to do. They've done this a zillion times and can make a recommendation based on the products they sell.
If you will be patient on the bay there are some deals that show thmselves from time to time if you want to go with springs. I recently lowered my 68 a little (4 in rear, started with 3 in front but it had too much rake and I just could not make my self like it so I went back to 2 in front ), simply because the 67-68 body begs to be dropped some. As Steve said spend some time on the suspension forum and read about the static drops. My truck is much firmer and still drives nicely especially for a 40 some truck. The spring kits are easy, if you are the least bit mechanical you can do it yourself in a weekend - replace tierods, ball joints and shocks at the same time- you are all ready there, might as well. If you mix and match off of ebay or the parts board, you can get springs for around $200,maybe less if you get lucky and are willing to shop for the deals, $100 for 4 shocks from kyb GR2 344068 work very nicely-thanks suspension forum for part # these can be bought at advance cheaper than the distributers :0, tie rods and ball joints $150(dont cheap out here) and a little of your time, and you are rolling low for less than $500
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#13 |
VA72C10
![]() Join Date: Mar 2008
definitely check ebay...and craigslist....I've seen the springs run around 80/pr shipped so only 160/4 springs and then get some shocks cheap (I got my front pair for my bagged truck new for $18 shipped by finding one from a different application on clearance that would give me the right compressed and open length...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
