08-11-2010, 02:52 PM | #1 |
lowering
Hello,I was wondering how much drop can i do before i need to install drop shocks and install a adjustable trail arm.thanks
08-11-2010, 05:02 PM | #2 |
Gearhead
Re: lowering
I would search in the suspension section, but my personal opinion is not much. I would recommend shocks with any drop more than 2", as far as the adjustable track bar (I assume thats what you meant??) goes I would say about the same. You really dont have to replace the track bar, but it will allow you to recenter the axle and also avoid weird handling traits when lowered. I would not go lower than 2-3" w/o the adj track bar.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
08-11-2010, 05:56 PM | #3 |
67-72 parts collector,…
Re: lowering
I would say 2" front spring only drop and 4" rear spring drop.
Drop spindles up front would be the best choice.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-11-2010 at 05:58 PM. |
08-11-2010, 08:22 PM | #4 |
Grandpa in the rustmobile...
Re: lowering
2.5 drop spindle and 4" lowering spring, drop shocks and adj trac bar is about what i would do for a mild drop
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-12-2010, 08:03 AM | #5 |
Re: lowering
thanks for the info have a good day kr cotter
08-12-2010, 09:20 AM | #6 |
Gearhead
Re: lowering
Thanks guys, I hadnt thought of spindles when I responded, they wouldnt require any shock change. I should have said no more than 2" on a spring drop.
