Senior Moment
![]() Join Date: Mar 2002
KYB Gas Shock ??
I’m looking at KYB Gas shocks from ECE for my 70
They have 2 #02-7510 GR2 Rear Drop #02-7515 Self adjusting Shock. KYB GR2 contains less nitrogen gas charge, therefore, is a softer riding shock. The Gas-A-Just has twice the nitogen pressure, so it is stiffer and provides better handling. Anybody have either one of these?? How do you like them? Thanks in advance Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 08-11-2010 at 03:57 PM. |
Between Trucks...
Re: KYB Gas Shock ??
I have the Gas-A-Justs. They are very firm. I'd go with the GR-2's. My truck is a C-20 FWIW.
Beat it to fit, Paint it to match... ![]() |
You can get the same shock part number 344068- whole thread on them on suspension forum around page 6, from Advance for $30 apiece- they should be a stock item. The GR2 are softer and not as hard on parts as the gas adjust- they tend to break front mounts on c10 according to the thread. I just installed 4 on my 68 and am happy with the way the truck rides now, not too soft but not harsh either.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#4 | |
Senior Moment
Also Suspension forum only goes to page 5???? and just to be clear you have the GR2's right?? Thanks for the Info
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 08-11-2010 at 05:25 PM. |
The page # is 9 in suspension forum, think you went to suspension FAQ. Original post was made by jared78 - The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension
kyb shocks/ part numbers The number is actually a kyb number stamped into the body, if you will search kyb online you will find several dealers/outlets that stock everything that the company offers. I bought my rear set from one of them and with shipping paid $70 for the pair to the door, shocks were like $28 each, but shipping ended up costing as much as tax ![]()
my gr2 rear drop shocks (5" springs) are stiff, while my stock height gas adjust fronts (with 2.5" spindles + 1" springs) are pretty soft. This might not help at all
'72 cheyenne super step, '05 long bed gmc |
I just purchased the KYB Gas Adjust today. I saw some posts about them being too stiff for a C10 and breaking the shock mounts. The truck will only see normal hauling duty and driving. Would I be better off with a softer shock?
![]() Join Date: Feb 2001
Some more info...http://67-72chevytrucks.com/vboard/s....php?p=4123195
http://67-72chevytrucks.com/vboard/s...d.php?t=298815
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-11-2010 at 10:55 PM. |
I have gas adjust's on my 72 4x4 blazer and they ride just fine but the 4x4 weighs a little bit more took my blazer to the scales and it was 4360 lbs.
Hope this helps
ScoobyDoobyDoo |
