08-11-2010, 09:13 PM | #1 |
Question for the room. :]
What is the diameter of the crankshaft balancer pulleys. Where can I purchase larger pulleys to create an overdrive situation. Would this not turn the a/c compressor faster at low rpm's??? Alternator also???
08-11-2010, 10:11 PM | #2 |
What?
Re: Question for the room. :]
Check out sites like this, there are options out there for what you are looking for.
http://www.marchperf.com/pg4.html
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-11-2010, 10:16 PM | #3 |
If you want OEM style V-belt pulleys, look at some of the Corvette restoration places. Different years and options had different size pulleys. You also can get the high-perf deep groove pulleys.
For water pump pulleys, make sure you get the correct pilot diameter. Some Corvettes (69-81?) Had a larger 5/8" shaft.
08-12-2010, 08:12 PM | #4 |
Is the mentality correct though, a larger crankpulley should turn the accessories faster?? Has anyone tried this??? :} Let's hear from the a/c experts out there!!! :}
