Old 08-11-2010, 10:04 PM   #1
SONOSADSACK
SONOSADSACK's Avatar
Looking for Blazer door info
I am aware of some of the differences between doors from a Blazer vs. a PU but not sure about the area where the window section meets the main door. As you can see in the first picture from my ’72 PU a nice clean gap where the two pieces intersect but in the next two pictures from my Blazer both doors have what appear to be a weld bead? Factory? Or is this someone’s fix? The Blazer doors do not have the ’72 anti-rattle screw like the PU either even though it is a ‘72. Was the weld possibly a GM temporary anti-rattle fix? How about a picture or two of your “I am 100% positively sure this is what it’s supposed to look like and it’s never been screwed with” Blazer doors? Bouncy?
SONOSADSACK is offline   Reply With Quote
Old 08-11-2010, 10:51 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Looking for Blazer door info
Have the outer doors been reskined with After Market (AM) panels? The AM panels don't match very well in those areas. Some one could have welded the gaps ??
D.PASSMORE is offline   Reply With Quote
Old 08-11-2010, 11:00 PM   #3
71swb4x4
71swb4x4's Avatar
Those welds do not look factory. Also, you should know that ALL blazer doors had the screw, not just 72. It is true that only 72 pickups had the screw, but all Blazers 69 - 72 had the screw.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-11-2010, 11:25 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Hmm, my Blazer never had the screws...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-11-2010, 11:38 PM   #5
70k5pk
70k5pk's Avatar
Smile Re: Looking for Blazer door info
I have had my 1970 Blazer since new and it has the screws.
70k5pk is offline   Reply With Quote
Old 08-11-2010, 11:56 PM   #6
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
I believe that the weld is factory (actually it should be a brazing). Can you peel the paint and see if it is a copper color? Mine is 100% original '72 Jimmy and it is the same way. I believe when they cut the frame work around the window it was from a stock truck door. Then they welded it there to keep the window and wind wing from moving the pillar around, giving it a little more structure. That's why often times you'll see cracks in there from all the stress that is put on the remnant piece of frame work left behind.
Cameron Gunlock
Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750
addicted2dunes is offline   Reply With Quote
Old 08-12-2010, 12:02 AM   #7
addicted2dunes
Here's mine, see the stress crack.... I've seen a lot of Blazers with the crack here and the crack you have pictured above on the truck door. I believe they're caused by just slamming the door against the weatherstripping repeatedly.
Cameron Gunlock
Old 08-12-2010, 09:50 AM   #8
turp mcspray
turp mcspray's Avatar
The doors on my blazer were still in original paint, and are welded as well.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-12-2010, 11:38 AM   #9
my90k5
72 K/5 Junkie
my90k5's Avatar
Those welds are much better than my factory welds, lol. Someone did a nice job on the welding IMO. Anti rattle screws here as well.
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 08-12-2010, 03:17 PM   #10
red71cheyenne
Back in the sticks
Thats really bizarre. Why don't mine have them? They have to be the original doors. Same color as the body, it was sitting for 20 years and they were as rusty as the rest of the truck.
2011 K1500 Suburban
2014 K1500 Pickup
Old 08-12-2010, 10:09 PM   #11
SONOSADSACK
Thanks for all the feed back guys…
Pretty hard to argue with an original owner but could it be GM popped em out both ways?
70k5pk Are the screws in yours doors recessed like the pick up doors or are they different in appearance?
addicted2dunes
I will buzz the paint down to see if they have been brazed. That would explain the very smooth appearance.
Old 08-12-2010, 11:43 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
My factory door was also welded and still in original paint. It has the screw holes and some black plastic inserts for the screws.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-12-2010, 11:49 PM   #13
SONOSADSACK
like this?
Old 08-12-2010, 11:58 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
yep, those are the ones....
Old 08-13-2010, 12:06 AM   #15
red71cheyenne
Back in the sticks
I'll take some pics of mine and post them too. They look just like my 71's doors, no screws or anything. I did reskin them and the lines around the wing don't line up so well, but I think I can trim them down some to get them to fit better. Pics to follow.
2011 K1500 Suburban
2014 K1500 Pickup
Old 08-13-2010, 12:18 AM   #16
red71cheyenne
Back in the sticks
Pics of my doors.
2011 K1500 Suburban
2014 K1500 Pickup
