08-12-2010, 02:05 AM | #1 |
i need pics of a few things on your truck...and info
1979 chevy k20 4x4 silverado with air conditioning and small block 350/350 tranny.
will the guage cluster from a 1982 suburban fit in this truck?what would ned to be modified,if anything? im a novice with air conditioning,but i have all brackets,good compressor,and lines,condensor etc.i know i gotta bolt it on,and hook the lines up n stuff.but what should i buy to get this going?the r12 to 134 kit and cans of freon?and anything i should do to prep and make sure its gonna work or whatever?sorry for the confusing question,im just not good with air conditioning.and it gets to 120 in the day here. AND-when i turn the blower motor on like the fan,air is only coming out down by the feet area and nothing much out of the vents.all the ac duct is good and intact as well.its got me puzzled. AND-as for newer power seats,i installed some in my truck(yes,all reinforced) where should i tap into power at?im not exactly sure how you guys have done that. ok,if anyone has pics of these things it would be GREAT cause trying to explain it would be a tad confusing. anyone got a picture of the ac blower motor area,all that stuff for ac and heater etc,im trying to look at the electrical where some stuff plugs in. sorry for all the questions,i just really need help.and this is the best chevy site out there. thanks guys
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
08-12-2010, 05:24 PM | #2 |
Re: i need pics of a few things on your truck...and info
dam,noone?
08-12-2010, 05:40 PM | #3 | ||||
Getting Old; Going Broke
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
08-12-2010, 05:50 PM | #4 |
08-12-2010, 05:54 PM | #5 | |
08-12-2010, 06:44 PM | #6 |
excellent! thank you. i checked and found a small rubber vacuum line going from the ac side of the engine bay thats broken,so ill get that fixed and see what happens.
thanks for all the info.
08-12-2010, 08:54 PM | #7 |
Robert Olson Transport
the only th ing im going to add to what Randy said is that when you run the wire to the battery clip in the fusebox be aware that you should have a fuse in the line to the seats.. 25 amps should be good and make sure you use a thick enough wire to handle the draw
08-13-2010, 07:57 AM | #8 |
make sure you check/replace the vacuum hose going to the vacuum resevoir (black ball). amazing how a new vacuum line help everything work.
84 Scottsdale LWB K10 Rooting against the cowboys is almost as fun as rooting for the GIANTS! |
