Brothers truck show july 11 2010
Hey I need some help. I talked with a vender at the show and can't rememberthe name of the company. It was the corvette suspension vender.
if anyone has that info. I could use it. Thanks
1952 Chevy 3100 1986 Corvette Suspension 350 motor Tune Port Injected |
It's Better With Nitro
Re: Brothers truck show july 11 2010
I can't remember the name either. I bet if you call Brothers, they will tell you. 1-800-977-2767
Flat out engineering makes the bracket kits to install C4 suspensions in AD and TF trucks.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
Tcihia65 Thanks That was it
Might want to check out Rob at No Limit Engineering
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
