Fel-Pro Weekend special Bump and Grind Garage
Just $29.95 per set Why pay more for your Performance Parts? Compare with Jeg's or Summit @ $43.95 Felpro KS2600 Description: Complete gasket overall kit 1967-80 265, 283, 302, 307, 327, 350 V8 Engines Stock rebuild gasket kit Features: - Perma-Torque head gaskets (2) - Perma-Torque intake gaskets with blue Teflon coating - Blue stripe cork rubber valve cover and oil pan gaskets with rubber end seals - Water pump gaskets - Timing cover gasket and oil seal - Water outlet gaskets (thermostat) - Valve seals - Exhaust gaskets - Fuel pump mounting and distributor mounting gaskets Other: Characteristics: Part Type: Engine Gasket Sets Part Number: FEPKS2600 Gasket Set Type: Full gasket set Head Gaskets Included: Yes Intake Gaskets Included: Yes Valley Pan Included: No Oil Pan Gasket Included: Yes Rear Main Seal Included: Yes Exhaust Manifold Gaskets Included: Yes Exhaust Pipe Gasket Included: No Valve Cover Gaskets Included: Yes Valve Stem Seals Included: Yes Water Pump Gaskets Included: Yes Timing Cover Gaskets Included: Yes Timing Cover Seal: Yes Water Neck Gasket Included: Yes Fuel Pump Gasket Included: Yes Distributor Gasket Included: Yes Fuel Injector O-Rings Included: No Upper Intake Manifold Plenum Gasket Included: No Head Fasteners Included: No Quantity: Sold as a set CLICK ON LINK TO PURCHASE-NO PROMO CODE REQUIRED "]http://www.mcssl.com/store/mikesbumpandgrindgarage/performance/felpro/fle-pro-ks2600-"] 5 only at this price- in stock Ends 8/14/10 at 4:00 est Last edited by mbgmike; 08-12-2010 at 05:43 PM. |
| Bookmarks |
