08-12-2010, 06:59 PM | #1 |
BBC in 72 GMC Burb - exhaust help~
I have pics of my burb posted here and appreciate all of the insight I get from reading other posts and seeing the pic's - great work everyone!! I am wondering if anyone else has done the move that I have....2" forward so the engine would clear the firewall? If so, how do you work in headers without having to give up a left arm and leg?? i had to notch the frame to get it all to clear where it tapers up by the exhaust - and - now I would love to have better looking pipes if anyone can steer me in the right direction. Please and thanks
08-12-2010, 08:06 PM | #2 |
its all about the +6 inches
Re: BBC in 72 GMC Burb - exhaust help~
why would you need to move the engine forward? My big block clears the firewall no problem
08-12-2010, 08:38 PM | #3 |
It is a 72 GMC 4x4 - she was originally a SBC - and I got a wild hair to go crazy - so I had a 454 built up - when I went to put everything in - it kept hitting the firewall - I talked with Dave @ Early Classic - he said to move everything forward 2" - I am not sure the 72 4x4 came a big block - if it did the crossmember must have been different - not sure - even moving 2" forward - the HEI is still about 3/4" from the firewall -
08-13-2010, 03:25 AM | #4 |
Devil's in the Details
There's a whole thread on the board here dedicated just to BBC engines in 4x4s. I had to chop and weld my firewall on both sides to fit my 454 without modifying the mounting points of the motor itself. I've got a set of headers hooked up to it (had a SBC w/ headers before and I already had a small notch in the frame) and the only problem I have run into is on the passenger side where the tube hits the bottom shackle bolt. My best approximation to a solution in my case is going to involve a ball peen hammer applied directly to that area.
BTW, no 4x4 came with a BBC from the factory in our year range.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
08-13-2010, 06:17 AM | #5 |
Thanks Beezleburb!
I have had people tell me there were BBC's in them - but I chose to believe otherwise! |
08-13-2010, 12:53 PM | #6 |
mine clears fine with the big block motor mounts installed.
