rear suspension
does any one know where i can buy the things that are welded to the rearend the bolt to the trailing arms.? the things the ubolts go through
optomistic ah-so
Re: rear suspension
Is this for a 100 point resto or for a performance upgrade?
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
Re: rear suspension
im puttin a 12 bolt in it
Re: rear suspension
http://Classicparts.com (1960-72) Weld On Rear Axle Seats $39.95
Ken B ![]() 60 Chevy Apache 08 Chevy Silverado Z71 Why buy something when you can build it for twice the price.. ![]() Just because something can be done doesn't mean it should be done... |
Re: rear suspension
optomistic ah-so
Re: rear suspension
Re: rear suspension
mine had the factory gm55t in it. thanks for those two sites
Re: rear suspension
Try CPP or ECE. Both should carry what you're seeking.
"Where were you in '62?"
![]() Join Date: Jul 2004
Also check out the guys:
![]() http://www.competitionengineering.com/default.asp You may see something that might tickle your fancy. http://www.competitionengineering.co...s/chassis2.asp
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-14-2010 at 07:42 PM. Reason: http://www.competitionengineering.com/articles/chassis2.asp |
Re: rear suspension
I went with CPP for mine. They sell a complete conversion kit. Comes with the trailing arm perches to weld onto the rear end, along with the panhard bar mount to weld on there, hardware, and an adjustable panhard bar.
Here's a link http://www.classicperform.com/Store/...ck/6072RCK.htm |
Re: rear suspension
nice i might get the kit. how much is it
#12 | ||
Re: rear suspension
#13 |
Re: rear suspension
im gonna get that kit. thanks for the help
