08-12-2010, 10:40 PM | #1 |
is very serious
STL craigslist
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold 1969 C-10 2wd fleetside LB 327 3spd - sold 1969 C-10 2wd fleetside LB 350 th350 - sold 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. |
08-13-2010, 04:00 PM | #2 |
Scrapper 1
Re: STL craigslist
that is a steel for a 2 ton truck only thing i change is i put a auto in it with a 700R4 and be done with it and add the wood and make it a driver
one last think i will say about old truck But the Factory Re pop wire harness for 700.00 and you will never have a wiring problem again and put the Hei in for the 6 and install power brakes and power steering and if you like Put disc brakes in just to make it more safer to drive |
