Old 08-13-2010, 07:59 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
3spd same as auto?
Is automatic linkage the same as 3spd.on column?
My lower front linkage for my 3spd on the column is cobbled I think. The rod slides up and down in that pipe thing with the hole in it..
Can I take the parts I need off of an automatic truck? Will it be the same? Or do I have to get em off of a 3spd manual...thanks, check my build thread for pic of what ive got (bolt 2 washers and funnny pipe thing with hole, thank you)
John
1999 Toyota Tacoma 4x4
Old 08-13-2010, 09:03 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 3spd same as auto?
Build thread is too long to locate what you have but I used the column off an automatic to convert my 69. It's a lot easier and that way you can take all of the linkage involved not just the column.
re. making yours work. I'm not sure if you can make the 3 speed manual column work or convert it to automatic without a lot of hassle.
68gmsee is offline   Reply With Quote
Old 08-13-2010, 10:01 AM   #3
cdowns
cdowns's Avatar
no you need a manual column for a manual transmission
Old 08-13-2010, 04:40 PM   #4
oldblue1968chevy
No no no not the actual column, the arm that holds up the linkage, my linkage bar falls off, and I cant shift R N 1
I dont need the column, I need some of the hardware for the shift ears that hold up the rod...I need to know if 3spd manual hardware parts are the same as auto..I think the bushings are the same...so would the rest be the same?
John
Old 08-14-2010, 08:12 AM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
From what I've seen the parts I think you are referring to are the same. The auto and manual columns use the same upper & lower bushing 67-70 the ones I have messed with. Make sure you have the metal spacer tube that goes through the bushings. Without it when you tighten the bolt that adjusts the rod it will lock the rod to the arm and not swivel like it should.
Here is a pic of mine on a 70 truck column. It does not have the rubber bushing
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-14-2010, 11:56 AM   #6
oldblue1968chevy
its a busy weekend but i'll get some pics of mine....
I think im missing the metal sleeve that goes thru the rubber bushing, and I cant tigthen the arm up (just slides when i try to shift.)
So the parts are the same (hardware bushings for top linkage on column) NOT lower parts on trans
John
Old 08-14-2010, 06:54 PM   #7
oldgold70c10
Who's got steelies?
Here is a pic of my friend's 3 on the tree linkage:
The part that pinches the rod and allows it to swivel is the same as the auto. It uses the same rubber bushings, and the trans. end uses the same hard plastic bushing with a shoulder, just like the auto uses. Other than that, nothing else interchanges. We replaced the plastic bushings at the trans end with one made from brass tubing on both trucks, and I found a place that sells repro rubber bushings for the upper end, but had to reuse the insert tube, because the one that comes with the repro is too small. It tightened up the shifter, but it stayed that way for only about a year. It is sloppy again, and I'm planning on making a bushing out of brass or bronze.
My Truck Page
My Youtube Channel
Old 08-14-2010, 07:46 PM   #8
oldblue1968chevy
thanks a BUNCH for the picture man I really do aprreciate it,thanks!!!!!
The collar on the trans bushign goes IN or out? Thank you!
Im missing some parts for sure...and I got the rods backwards..
John
Old 08-15-2010, 01:29 AM   #9
Sublvr72
Sublvr72's Avatar
I just threw all these parts in the dumpster after converting mine to auto. I would have sent you all of my linkages for free if I would have known
Sublvr72 is offline   Reply With Quote
Old 08-15-2010, 12:09 PM   #10
oldblue1968chevy
lol hindsight is 20 20 so they are the same then..kinda what I thought...
John
Old 08-17-2010, 07:12 PM   #11
oldgold70c10
Who's got steelies?
I honestly don't remember, but I want to say that the collar goes against the trans lever, because it seemed it was opposite the way it was on the auto.
I hope that helps you.
My Truck Page
My Youtube Channel
Old 08-21-2010, 08:07 PM   #12
oldblue1968chevy
Ok heres some of the hardware for the front (lower) shifter on the column
the middle 2 come from a stock 67 plain jane gmc
the outer pieces came off my 68 which is jiger riged to heck lol
Do the outer pieces go on my truck or are they off something different? I may go back and get everything off the 67 gmc to less complicate the situation..thanks
John
