Old 08-13-2010, 06:54 PM   #1
Frijolito1988
5 Lug rear end swap
hey guys, Im looking what the easiest / easily available swap . I already swapped the front drum for 5 lug disc brake . Now as far as the rear end goes, would swapping axles be the easy way ? Or just swapping coplete rear end ? I found a local rear end with 3.73 gears / Posi / 5 lug for $450 . Anybody know of a place in so cal that have these rear ends a bit cheaper ?
EDIT TO ADD
I have a 68 SWB 6 lug C/10
Frijolito1988 is offline   Reply With Quote
Old 08-13-2010, 08:23 PM   #2
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: 5 Lug rear end swap
If the 3.73 gears is what you want, I'd swap the rear end. I did it on Old Yeller and it's no big deal. If you pull the axles there's a lot more work to do. $450 probably isn't too bad for a rear end with a posi and 3.73s. It depends on what brand posi and how much abuse it's seen.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 08-13-2010, 09:26 PM   #3
Frijolito1988
Yeah thats true, although at the moment im just looking at the cheapest possible way to some 5x5 lugs on the rear of this truck to mount some American Racing Hopters I have . I always assumed that used rear ends where in the $150-200 range
Old 08-13-2010, 10:02 PM   #4
Old Yeller 1970
DON'T TREAD ON ME
Well if it was an open rear end with 3.07-3.43 gears, then yeah $150-200 would be right. The 3.73 gears and posi are what adds to the price. If you don't want the extras keep looking and you'll find what you want in your price range.
Old Yeller
Old 08-13-2010, 11:36 PM   #5
Sublvr72
Sublvr72's Avatar
450 isn't bad for a complete 5x5 rear end with posi. Keep in mind the rearend you are looking for is only a 2 year production. I paid 300 for the one that I used on the suburban when I went from 8 lug to 5.
Depending on where in SoCal you are, there's a good rear end place in the valley called Hoopers.
Sublvr72 is offline   Reply With Quote
Old 08-14-2010, 01:27 AM   #6
KrazyRay
KrazyRay's Avatar
I just sold a 71 5 lug coil for $250 in norcal. It was plain 3.07 non posi and it sold fast. I think the value of these rear ends are going up because they are hard to find.
KrazyRay is offline   Reply With Quote
Old 08-14-2010, 01:36 AM   #7
Frijolito1988
If i can find one with in the next couple weeks under $300 Id get it, if not i might as well get the modded 3.73 with posi. Thanks guys
Old 08-14-2010, 07:46 AM   #8
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
EDIT TO ADD
Is the one with posi for $450.00 off of the 71' in the junk yard you found? I responded to the PM you sent me. Give me a call, I left my cell number.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 08-14-2010, 08:25 AM   #9
OARNGESI
OARNGESI's Avatar
Can you weld they make a kit so you can use a 73/87 rearend
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
