Old 08-13-2010, 07:14 PM   #1
Mark Hanna
Bendix brake booster not working with factory brackets?
I bought a Bendix remanufactured brake booster from Autozone and when I went to put it on my 72 C10, I noticed a problem. I should first clarify that the brackets I am using came from a 69 GMC 3/4 ton truck. I thought that they would be the same as the ones that should be on the 72, but when I put the brackets on the booster and connecting the pedal linkage rod, I found that the linkage sticks out about an inch and a half further than the surface of the bracketd that mount to the firewall. are the brackets different? Do I somehow have the wrong booster?
Here is a link to a picture of the booster i bought
http://www.bobschevytrucks.com/1967-...re-charge.html
Mark Hanna is offline   Reply With Quote
Old 08-13-2010, 08:59 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Bendix brake booster not working with factory brackets?
There are two different brands of booster.I don't remember the other brand name.IIRC the brackets are different.I think one brand is one 1/2 ton and the other on 3/4 but I don't know the particulars well enough to tell you what's what.
One of the BB vendors should be able to get you pointed in the right direction.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-13-2010, 09:05 PM   #3
rsavage
rsavage's Avatar
There are at least 2 different kinds of firewall booster brackets used. One set is shorter than the other and, if I remember correctly, works with the fatter smaller diameter dual diaphragm booster while the longer set works with the single diaphragm larger diameter booster. If you have a single diaphragm, take it back and see if the dual works with your bracket.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 08-13-2010, 09:10 PM   #4
srea76
srea76's Avatar
one booster is bendix and the other is delco moraine
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 08-13-2010, 10:17 PM   #5
rsavage
rsavage's Avatar
There are after market brands of the boosters too. It is the type that determines what brackets will work - single or double diaphragm. Autozone lists the dual as part number 54-71011 as an example for a 69 C20 and the larger single as part number 54-73709 for a 69 c10. Both are manufactured by "cardone" and are listed as bendix type. Take a look at the autozone site. If you have 69 c20 brackets then my guess is that you will need the 54-71011.
1961 C1 Corvette
2021 Durango RT 5.7
Old 08-13-2010, 11:09 PM   #6
swierker
swierker's Avatar
There is a thread in the FAQ section that shows the different versions of brake booster and MC's that our trucks have. You should check it out, it has some good info.
http://67-72chevytrucks.com/vboard/s...d.php?t=214559
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
