Need Foam Strip for thr hood
Well I got my 67 hood built for the 69 truck and need the foam pad to go between the hood supports and hood?
Anybody know a vendor that has good stuff??
1950 Chevy 1500 1961 C-10 1969 C-10 1971 Chevelle 2008 Dodge HD3500 Tow Rig |
Active Member
![]() Join Date: Jul 2007
Re: Need Foam Strip for thr hood
Most all of the vendors in the "vendor" section have the foam pads.
Word of caution when installing: Use care when prying the reinforcing strips to install the new foam. If you use a sharp object like a pry bar or screw driver it can leave a mark on the top of the hood. (from experience. ![]() I shaved a wide, flat piece of wood at one end similar to a wood shingle to pry the metal strips. I tapped them in until I was able to insert the foam. |
