Old 08-14-2010, 03:54 AM   #1
old_1966_GMC
i need parts list for brake swap
i need a list of all the parts i need to do a simple drums to disk brake swap i wanted to keep my stock crossmember from my 66 3/4 ton gmc im thinking of getting the parts i need from my local picknpull sence im just a few blocks away from it and some type of instructions this will be the first time i will do this swap.
i need a whole list of part and from what truck year and model
old_1966_GMC is offline   Reply With Quote
Old 08-14-2010, 11:16 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: i need parts list for brake swap
You can get everything you need from a 73-87 truck (up to 91 on Burbs). Swap the complete crossmember, or A-arms out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-14-2010, 01:13 PM   #3
old_1966_GMC
i wanted to to keep my stock crossmember and justo with the brake swap do u know what i should go and look for
Old 08-15-2010, 12:59 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
If you keep the crossmember, swap everything from the A-arms out including the tie rods.
Articles-
"Refining Sierra"
Old 08-15-2010, 03:03 AM   #5
old_1966_GMC
i been looking around some threads where they end up keeping the crossmamber and control arm hey thanks for the help im getting from u this is my first project i'll be doing same as swaping fron and rear brakes
Old 08-19-2010, 09:25 AM   #6
slapthefunkyfour
Super Newb
slapthefunkyfour's Avatar
I'm planning on doing the same thing this weekend. I also have a 66 3/4 ton.
I found a guy locally who is selling parts from a 72 3/4 ton, and I was hoping that the front suspension from that would fit my truck.
What if I only replaced the spindles? Will the later spindles fit on the earlier control arms? Do you really have to do the entire front end?
Crap, I just got to thinking. I'm guessing the orginal brake master cylinder will not work for disc brakes. Will I also have to upgrade to a power booster and a better master cylinder?
Well, back to searching older posts.
slapthefunkyfour is offline   Reply With Quote
Old 08-22-2010, 01:27 AM   #7
Captainfab
60-66 Nut
The '71-'87 balljoints should fit the '66 control arms. I know the uppers will fit, and I'm about 90% that the lowers will also. Then the spindles, rotors, calipers, etc will bolt up. And yes you will have to upgrade the master cylinder and add a proportioning valve. You can get those from the same '72 parts truck. I offer a booster bracket that bolts onto the firewall using existing holes, or you can use the '72 booster and drill the holes to mount it. I have the steering box adapter plates as well.
Old 08-22-2010, 01:58 PM   #8
old_1966_GMC
Yes you can use it for a drum/drum brake setup. Use of this bracket has no direct effect on your braking system. This bracket simply allows you to add a power brake booster to your truck using a factory brake booster and without drilling more holes in your firewall. My '66 Suburban currently has drums all around with this same bracket. You'll just need to use the correct master cylinder
how is your drum setup i really wanted to keep my drums sence they were just rebuilt by PO but my research on brakes were just to do a swap to disk setup.Is it really nessary to do the swap do u have any issue with your drum setup
