Old 02-22-2003, 01:47 AM   #1
MidniteChevy68
MidniteChevy68's Avatar
Question about lowering blocks..
Is it possible to use a set of lowering blocks in the rear, if it has coil springs?
68' Chevy truck longbed: flows, 4/6 drop, k&n filter, GMC front clip, and 20s
MidniteChevy68 is offline   Reply With Quote
Old 02-22-2003, 02:53 AM   #2
Shane
Shane's Avatar
yes ... all you need are the blocks and longer U-bolts.
Shane is offline   Reply With Quote
Old 02-22-2003, 04:47 AM   #3
sgtjed
What if?
sgtjed's Avatar
whats the max you can go on lowering blocks?
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 02-22-2003, 06:40 AM   #4
MidniteChevy68
But were would you place the blocks? because I have seen trucks with leaf springs that have them and I know that it can't be installed the same way. I want to add a 1in lowering block to level my back with the front.
Old 02-22-2003, 09:00 AM   #5
72c10
72c10's Avatar
if you have coils it goes between the rear axle and the trailing arm, (under neath the axle, and above the trailing arm) with longer U bolts
72c10 is offline   Reply With Quote
Old 02-22-2003, 09:20 AM   #6
crazy longhorn
Fabricate till you "puke"
A 2" block is prettyclose to max if you are running 15" wheels.....much more, & you will be below "scrub lines". crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-23-2003, 11:55 PM   #7
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
put 3 inch drop blocks in .....drop in a 800hp motor, lighten up the front...and put gas shooting nozzles on the rear bumper , i think this will show using the scrub line to its full potential
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 02-24-2003, 01:44 PM   #8
crazy longhorn
LOL! Did you like those fire burnouts from the 60s?
