Old 08-14-2010, 08:38 PM   #1
BROWN 70
BROWN 70's Avatar
Factory Gauge Readings
Hi Guys, new here, just a question about the factory oil pressure gauge in my 70 gmc. it is a mechanical gauge, but im not sure of the indication lines. does it indicate 15,30,45 or 20,40,60? or something else? i know silly question but i,ve never known. LOL thanks for any replys, BROWN 70
BROWN 70 is offline   Reply With Quote
Old 08-14-2010, 08:45 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Factory Gauge Readings
60 pound gauge unless from a c-40 or bigger truck. Than it COULD be an 80 pound. (depending on engine application)
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-14-2010, 09:51 PM   #3
71swb4x4
71swb4x4's Avatar
Of course after 40 years, who knows how accurate it even is. Should be close enough for most people's needs though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-14-2010, 09:56 PM   #4
chevychompers
chevychompers's Avatar
I have a 70 chevy 3/4 ton and it is stamped on the gauge 80 lbs. 350 engine.
chevychompers is offline   Reply With Quote
Old 08-14-2010, 10:14 PM   #5
too much stuff
Roadtrip!
I would guess it was changed out at some point. Alot can happen in 40 years. I have seen alot of clusters over the years and never seen an original with an 80# gauge in the 1/2 -1 ton series...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 08-15-2010, 08:21 AM   #6
BROWN 70
BROWN 70's Avatar
Thanks for the replys guys. so do you guys think it is stamped on the back of the gauge? i,ll look. BROWN 70
Old 08-15-2010, 10:15 AM   #7
too much stuff
Roadtrip!
It should be on the front of the gauge down low. You will probably have to pull the gauge to read it.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
