Old 08-15-2010, 10:12 AM   #1
my67c20
Rearend Options
Currently have a 4:56 rearend. Really like doing 2 wheel burnouts. Really like the 4:56. Currently powered with a 383 and 4 speed granny. Would like to be able to take this thing to the track but yet also use it on the freeway. Currently have 8 lugs wheels. Like the 8 lug wheels.
What direction should i go with the rearend? Ford 9", find a older model posi? Not afraid to have to modify things abit to fit. Sorta budget minded, looking for a good winter project.
my67c20 is offline   Reply With Quote
Old 08-15-2010, 11:02 AM   #2
haysonj
haysonj's Avatar
Re: Rearend Options
I bought my 14 bolt in a wrecking yard for $300. It has 4;10 gears and is out of a 73 one ton. All I had to do is weld on new perches but then I have leaf springs.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-15-2010, 12:29 PM   #3
Mike Bradbury
Mike Bradbury's Avatar
Re: Rearend Options
I put alincoln 9" in mine, has 5 on 5 lugs standard disc brakes and s light and strong. Expensive though.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 08-15-2010, 12:38 PM   #4
LONGHAIR
Re: Rearend Options
Currently have a 4:56 rearend. Would like to be able to take this thing to the track but yet also use it on the freeway.
4.56 and freeway do not go in the same sentence unless there is some kind of overdrive involved. The type of axle or the posi unit have no bearing on this, it is purely an RPM thing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-15-2010, 07:01 PM   #5
my67c20
Re: Rearend Options
Sorry about that grammer error longhair. Let me try to rephrase that. I would like to take this thing to the track and with a few gearing modification also be able to use it on the 4 lane, concrete street.
Haysonj, nice setup, like the color, that have 8 lugs
Old 08-15-2010, 07:26 PM   #6
haysonj
haysonj's Avatar
Re: Rearend Options
Yes same as the Dana 44 in front
Old 08-15-2010, 11:17 PM   #7
factorystock
factorystock's Avatar
Re: Rearend Options
The easiest conversion would be Dana 3.54 axle assembly out of a coil spring 68 thru 72 3/4 ton(big block pickup or suburban). These have the crossbar bracket you need. This is the most freeway friendly set up that is a bolt in. Problem is finding one quick.
factorystock is offline   Reply With Quote
