control arms 64 c-10 help
i brought some new control arms and i am installing them and i was told to align the hole on the shaft with the bolt head on the cross member clamp well my old control arms had only one hole on the shaft and new ones have 2 and the ones on the new shaft are farther apart than the two clamps on the cross member so do i align the front hole on the shaft with the front on the clamp or the rear one
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: control arms 64 c-10 help
Have you compared the hole placement on the new control arm shafts to the hole placement on your originals? You will want to position the new ones in the same position front to back as your originals. If this isn't possible with the new control arms, then they are not the correct ones.
