Old 08-15-2010, 02:05 PM   #1
CVA59
Clutch Question
I have a I6 in my 64 with a 3 on the tree. I am putting a 283 in it and i want to keep the original tranny. However, the clutch pivot arm is bolted to the side of the I6 block. What do i have to do to get around this so i can drop in my V8?
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 08-15-2010, 02:34 PM   #2
P_A
P_A's Avatar
Re: Clutch Question
You will need a ball stud like this that screws into the side of your 283.
Paul
1964 C10 SWB Fleetside-396/M21 4 speed
1957 Belair-283/M21 4 speed
1972 Camaro
P_A is offline   Reply With Quote
Old 08-15-2010, 02:51 PM   #3
CVA59
Re: Clutch Question
After looking at it again, it looks like the entire pivot assy is too far forward for where that pin screws into the 283 block. Looks like a good 6+".
Zack
www.23t.weebly.com
Old 08-15-2010, 05:18 PM   #4
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: Clutch Question
My 350 has 2 places to screw the pivot ball into. One is right by the bell housing and the other is about 6" forward from there by the dipstick.--Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 08-16-2010, 12:53 AM   #5
Captainfab
60-66 Nut
Re: Clutch Question
If your 283 doesn't have that forward hole or at least the boss so you can drill and tap it, you're SOL.
Old 08-16-2010, 09:48 AM   #6
CVA59
Re: Clutch Question
LOL, Thanks Fab. I will check it today. If it doesn't have it looks like it will be time for an automatic tranny.
Zack
www.23t.weebly.com
Old 08-16-2010, 10:32 AM   #7
TheDark1
TheDark1's Avatar
Re: Clutch Question
http://sdparts.com/details/scoggin-d...ts-center/sdcb
Name:  clutch pivot ball.jpg
Maybe you could use something like this. I think this is for an LS based engine, but you could make one similar to it I'm sure.---Jeff
1997 Formula WS6
Old 08-16-2010, 10:34 AM   #8
TheDark1
TheDark1's Avatar
Re: Clutch Question
This one was on a Nova site. Looks like it can be done a few different ways or styles.
1997 Formula WS6
Old 08-16-2010, 10:56 AM   #9
CVA59
Re: Clutch Question
Heck yeah, now were talking. I am guessing i will have to take something like and modify it to work. I hate the thoughts of having to drop in an automatic, LOL. Thanks for this info.
Zack
www.23t.weebly.com
Old 08-16-2010, 11:14 AM   #10
TheDark1
TheDark1's Avatar
Re: Clutch Question
It seems like I remember a bracket just for these trucks that went from the bellhousing to the motor mount pad. I don't know if I'm hallucinating or not. I was a kid when I started working on these things, so some of that info is "foggy" at best. Maybe LilRed can shed some light on this. He has a ton of these trucks. I'd do anything to keep a shifter in my truck.--Jeff
1997 Formula WS6
Old 08-16-2010, 11:56 AM   #11
Rogue
Airport Bum
Re: Clutch Question
Originally Posted by CVA59 View Post
I hate the thoughts of having to drop in an automatic.
Yeah, That would be terrible!
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 08-16-2010, 12:03 PM   #12
CVA59
Re: Clutch Question
Yes it would. I will contact lilred and see if he knows something
Zack
www.23t.weebly.com
Old 08-17-2010, 12:16 AM   #13
Captainfab
60-66 Nut
Re: Clutch Question
I've seen the brackets for the rear location, and ones in between the front and rear location. But fabricating a bracket for the forward location will be a PITA since you need to find a place to brace the front of that bracket. I'm not sure where that would be is why I didn't mention it. Anyway another option to this dillema would be to go with a hydraulicly operated clutch.
Old 08-17-2010, 12:22 AM   #14
padresag
Re: Clutch Question
why not look at your 283 first before speculating what you have to do. you should find a threaded hole in which to install the proper ball stud
ron
padresag is offline   Reply With Quote
