Old 08-15-2010, 06:17 PM   #1
Rudy67chevy
rudy67chevy
Rudy67chevy's Avatar
04 chevy avalanche front passenger window won't roll down
I check the circuit that goes to the passenger side window. I even swap the driver side circuit to see, if the other was bad. still didn't work... Any solutions? Anyone could give me.
Rudy67chevy is offline   Reply With Quote
Old 08-15-2010, 08:58 PM   #2
clinebarger
Re: 04 chevy avalanche front passenger window won't roll down
You need to check for power & gound to the window motor itself first. If you have power & ground to the window motor, the motor is bad.
clinebarger is offline   Reply With Quote
Old 08-16-2010, 10:30 PM   #3
Rudy67chevy
rudy67chevy
I would need to remove the door panel to check
Old 08-16-2010, 10:33 PM   #4
clinebarger
Yes you have to remove the door panel.
Old 08-31-2010, 09:01 PM   #5
jocko
jocko's Avatar
not sure if it helps - but I've been through 4 motors on my driver side door (go figure). First one replaced under warranty by chev - the rest on my own dime. The last 2 I replaced myself - it was surprisingly not difficult at all.
My last great find was this - Autozone usually has the motor and race in stock, about $90 (I think) - and it's got a lifetime warranty! It went out once, and they absolutely did replace it for free, all I had to do was dump the broken one on the counter. Pretty good deal. They may not be the quality of a GM part - but in my case, the 2 Autozone motors lasted longer than the 2 GM motors... (breaks my heart to say that)
Anyway - in case you determine it's the motor once you look inside the door - this might help you out a bit. The other failure I've noted is the cabling gets frayed and comes apart on the rollers - that was the reason I replaced on of the motor/race combos.
jocko
