08-16-2010, 03:08 AM | #1 |
Moderator
My 4.5/0 ba-donk-a-donk drop
I started the install of my "budget drop" kit. I picked up a pair of McGaugheys 2.5" drop spindles from a parted project for $50. I used a set of factory HD front coils, cutting one full coil off of each one. Afterwards, I measured 27" from the garage floor to the bottom lip of the fenderwell on both sides, running 215/70's on a set of 15x7 rallyes. Prior to swapping out the factory 1/2 ton coils and factory spindles, I measured 31.5" and 31" respectively. I figured with this combo I have around a 4-4.5" drop in front. I am going to need shorter sway bar brackets, as my floor jack is no longer able to slide underneath from the front. New shocks/alignment will also follow.
I also put in 02 Wrangler coils in the rear (free), hoping for a 4" drop. As you can see, that did not happen. Even with a lot of heavy junk in the bed, it remained at the same height as the factory coils. Can't figure, everyone else says they get 4" out of them. Oh well, with the front the way it is now I am going to go with a 5" rear drop, as I prefer a slight rake rather than a level stance that the 6" coils give. Before that however, I plan to cruise around as-is, with the Ba-Donk-a-Donk look Here are some pics, I also got the front end/doors/cab/hood aligned and the 402/400 driveline installed, so this is with full weight. Looks like a stinkbug
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-16-2010, 05:59 AM | #2 |
Re: My 4.5/0 ba-donk-a-donk drop
Looks really good down in the front
70 SWB STEPSIDE 70 BLAZER 09 challenger |
08-16-2010, 09:46 AM | #3 |
20' Daredevil (Ret)
By golly, a pair of L78-15 bias-ply tires out back and you be period-correct redneck stylin'....
08-16-2010, 10:43 AM | #4 |
Between Trucks...
Looking good Scott. You've got a lot done to it since I saw it last.
Beat it to fit, Paint it to match... |
08-16-2010, 10:54 AM | #5 |
looks pretty good
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-16-2010, 04:10 PM | #6 |
Kill Bill...et
When I read "donk" in the title, I half expected 24" rims with a lift. Pleasantly surprised. Nice look!
08-16-2010, 04:55 PM | #7 |
dazed and confused
i had one do that one time found out the exhaust got in the way and wouldnt let drop. i like the truck. of course you do need a chrome rear end cover to be correct!
members met: redbaron69, billsbowtie,nc67 |
08-16-2010, 09:30 PM | #8 |
Grandpa in the rustmobile...
I still cant figure out why it didnt lower the rear with the jeep coils..lol could they be 'lifted' coil springs lol?
Front looks good, STEAL ON THE DROP SPINDLES!!! Nice
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-19-2010, 02:40 AM | #9 |
Moderator
I got the driveshaft put in today...was able to find a combination U-Joint to run the TH400 yoke, keeping the factory set-up I go on vacation next week, and hope to get it running then. I'll take a torch to the rear springs just for fun before I put in the 5" drop springs. I plan on driving it down to the exhaust shop (already got the mufflers in the bed) and getting it on the road...
08-19-2010, 11:25 AM | #10 |
Don't forget to shoot a "Rap Video" before you change the coils.Ba-Donk-a Do.......
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
08-19-2010, 10:46 PM | #11 |
lol^^ Im ridin cali i need a rap video for you tube lol
