Old 08-16-2010, 09:38 AM   #1
dragginmetal
here, just not logged in
dragginmetal's Avatar
Oil Pressure Sending Unit
1988 GMC 350 auto c1500 2wd
I pulled the '88 motor out and put a '92 in. On my '88 the sending unit is above the fuel filter. The '92 does Not have one here. Its a plug in that hole. Reading past post someone said the '88 has two sending units. One by the filter and by the distributor. The '92 only has the one by the distributor.
My question is where do i hook the wire that is hooked to the sending unit (by the fuel filter) on the '88 too, now that i have a '92 with only one sending unit. This seems to control my dash guage.
I tryed to take it off the '88 (sending unit by filter) and put it on the '92, but the hole in the '92 block seems smaller.....The sending unit by the distributor is the same on both motors. (both have 2 wires).
So how do i get my oil pressure gauge to work?.......Sorry for the long post, just trying to give all the details.....Hope all this makes since.
Name:  oil sending unit #2.jpg
This is not on the '92.
Name:  oil sending unit#1.jpg
This is the same on both motors.
dragginmetal is offline   Reply With Quote
Old 08-16-2010, 10:40 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Oil Pressure Sending Unit
If the later motor only has the one sending unit, could it be that the later unit does both functions, whereas the earlier motor has to have both? I don't have the answers, but hope someone will.
Member Nr. 2770
Old 08-16-2010, 11:48 AM   #3
dragginmetal
ChevLoRay thats what i was thinking. Maybe the one unit on the '92 would be 3 wire and i could splice into it. But nope, thet are the same 2 wires and the same unit....Also the wire harness that came with the '92 is the same as the '88.(im useing the original w/harness that came in the truck('88)). The '92 has the wires for both units, but the one wire i need hooked up looks like it wasent in use on the '92.
Old 08-16-2010, 12:52 PM   #4
Boog
laying low
Boog's Avatar
On your 88 the unit by the distributor is for the oil pressure gauge. The one by the oil filter was discontinued a year or so later. Had to do with the fuel pump power circuit.
You should be able to take the brass threaded adapter down to a parts store and down size or upsize to fit the hole in the block so that secondary sender can be hooked back up.
Boog
Old 08-16-2010, 02:06 PM   #5
dragginmetal
Boog, My gauge is not working, but the one by the distributor is pluged in. You think that unit might be bad?.....The one by the filter is unpluged, but the truck runs good. I would like to do away with the one by the filter if possable, but i will go to the parts store and take a look.
Old 08-16-2010, 05:48 PM   #6
ChevyTech
The 1992s have a three wire sending unit by the distributor.
One is for the oil pressure gauge and two are for a fuel pump redundant circuit.
The 1988s have a two wire by the distributor and a one wire by the oil filter.
The one wire sender by the oil filter is for the oil pressure gauge, and the two wire sender by the distributor is for a fuel pump redundant circuit.
You can pick which way you want to go. You can use the 1988 setup with two sending units which will make it correct for the model year, which is what I would do. You could get a sending unit connector for a 1992 and wire it in and use one sender. Or you can leave them unplugged and see how lucky you are.
Be careful, the brass fittings break easily. Support them with a wrench.
Old 08-16-2010, 05:50 PM   #7
bwood
bwood's Avatar
You need to use the sensor from your 92 or get a new one. On the 88 trucks the one by the oil filter (looks about like a coke can) is actually for the gauge. The one next to the distributor is a switch (on/off only) that works with the fuel pump circuit. In 90 ( or somewhere in there) they did away with the switch and moved the sender up next to the distributor. Look into the harness for the 92, it should have 3 terminals.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 08-16-2010, 05:51 PM   #8
bwood
bwood's Avatar
ChevyTech got me, I need to type faster
2013 Ford F150 FX4
1982 Chevy C1500
2008 Ford Escape
Old 08-16-2010, 07:58 PM   #9
dragginmetal
Im going to get a reducer for the brass fitting, and use the (coke can) unit on the '92. I will let y'all know how it works. .......BUT, since the '92 does not have the (coke can) unit. How did the guage work? You can see in the pics same unit(both have only 2 prongs), same w/harness (both have 2 wires).
Unit on '88
Unit on '92.....same on both.
'88 w/harness
'92 w/harness.....same on both.
Old 08-16-2010, 08:07 PM   #10
ChevyTech
What was the 1992 engine in?
Did the 1992 vehicle have an oil pressure gauge?
Old 08-16-2010, 08:23 PM   #11
dragginmetal
It came out of a stock 1992 gmc c1500 2wd. It came from a wecking yard. I watched as they pulled it out of the truck. I did not see it run, so cant say if guage worked on that truck. But that is the w/hareness, and the unit that was in that truck.
Old 08-16-2010, 08:40 PM   #12
ChevyTech
I was fairly sure that the large can senders by the oil filter were not used as late as 1992 but I could be wrong.
I don’t have a 1992 schematic handy to look at.
The senders by the distributor that were also for the oil gauge were longer and larger then what is in your photos.
Look carefully at what is down by the oil filter and see if it is a broken off fitting. Maybe that is why it looks to small.
Old 08-16-2010, 08:53 PM   #13
bwood
bwood's Avatar
I think I read your post wrong, I was thinking you had a 92 and you were putting a 88 engine in. I read it backwards, you are putting a 92 engine in your 88. You will need to install the sensors from the original 88 engine on the 92 engine. You will still need the "coke can" pressure sending unit for the gauge. Straighten me out if I still got the years/vehicles wrong.
2013 Ford F150 FX4
1982 Chevy C1500
2008 Ford Escape
Old 08-16-2010, 08:58 PM   #14
ChevyTech
To be more clear, I agree with bwood.
Make the new engine match the way your 1988 was.
Old 08-16-2010, 09:14 PM   #15
ChevyTech
1991 GM 8 cylinder Oil Pressure Sending Switch Location
Source:
http://autorepair.about.com/library/...bl283a-lib.htm
Here is the best photo I could find:
Old 08-17-2010, 12:06 AM   #16
dragginmetal
Well post #16 and everybody is confused. Sorry abought that.
I was going back and forth, posting and working on the truck...I will make the new just like the old. Thanks for the replys.
