08-16-2010, 02:49 PM | #1 |
got the notches put in!
havent really worked on the truck in awhile but in the last two weekends, i upholstered the dash and door panels, lowered the front 2.5 and did a flip in the back, but my biggest acomplishment was building the notches for the back.
08-16-2010, 06:48 PM | #2 |
Re: got the notches put in!
Did you do a rear flip yourself, or did the kit not come with the notches? Or something else?
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
08-16-2010, 06:57 PM | #3 |
well I bought a flip bracket off ebay and installed it, then I a 12"x12" 1/4" plate and a piece of 5" diameter pipe. and cut it in half. I wanted to bolt them in, because I will probably want to go lower later so I can just take those out easy and build a step notch. all in all about 50 bucks. oh and i got drop shocks from CPP for 40 bucks for the pair. So about 90 bucks for the back.
08-17-2010, 10:51 AM | #4 |
got some more pics.
08-17-2010, 10:55 AM | #5 |
great looking blazer another inch down in the front it will be perfect
70 SWB STEPSIDE 70 BLAZER 09 challenger |
08-17-2010, 12:27 PM | #6 | |
Didn't understand why until I saw the pictures posted above...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
08-17-2010, 02:03 PM | #7 |
Low & Fast!
Nice job...
08-17-2010, 03:03 PM | #8 | |
And that's a great looking blazer!
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 Last edited by Davidmichael; 08-17-2010 at 03:04 PM. |
08-17-2010, 08:26 PM | #9 | |
It's not that you can't use a notch, just that no one makes one, at least that I am aware of. If you know of a company offering them, please post a link!
08-17-2010, 10:19 PM | #10 |
yeller
I don't know man, most aftermarket truck notches go over the frame and use about double the number of bolts you have in yours...hopefully yours won't fail. Not saying it will, but just letting you know how the truck ones are built and installed.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-18-2010, 08:44 AM | #11 |
http://www.airbagit.com/product-p/fli-che-04.htm
http://www.stillen.com/product.asp?i...KIT&c=SU&m=all Part number BEL6852 http://www.streetperformance.com/aut...604-100582vcb/ http://www.summitracing.com/parts/BEL-6852/ I don't know if they are different but at least they say it's for your Blazer.
08-18-2010, 11:05 AM | #12 |
I built it to mimick the universal ones. not the wrap around ones. I also plated the inside of the frame. so there is over a 1/2 inch of steel that those bolts are through. Now that you mention I have some material left over, I think im gonna weld it to the bottom so it wraps the bottom, and put a couple extra bolts there. Better safe then sorry. But failure is always an option, it is how we learn.
08-18-2010, 12:42 PM | #13 |
Low & Fast!
If your not towing with it you should be ok with that.
08-18-2010, 12:53 PM | #14 |
Good advice!
Notches such as these really do affect towing and load hauling capacities drastically, especially on leaf spring suspensions. If you aren't using your truck for towing or hauling purposes then no big deal. I am not preaching, do what you like, I just want you to be aware of what these changes do to the strength of the frame. Want to know more about why this is? Here is a thread from the 60-66 forum where this was discussed at length: http://67-72chevytrucks.com/vboard/s...ighlight=notch Last edited by lakeroadster; 08-18-2010 at 01:00 PM. |
08-18-2010, 01:01 PM | #15 |
Well I will not be towing at all, but sometimes i will have passangers in the back seat. Any feedback is good feedback, better than scrartching my head.
really appreciate it! gettin new tires this saturday, ill post more pics |
08-18-2010, 01:07 PM | #16 |
Low & Fast!
Good info Thanks for posting that link..
08-18-2010, 05:10 PM | #17 | |
I am not trying to argue with you nor am I out to prove you wrong!!!
I am just putting what I found so in the future if someone finds this thread they will see what was found. Quote:
That first one (airbagit) has promise. As I get my crew to a driving state and turn back to the Blazer, I will investigate it further. Thanks for the research!
08-18-2010, 05:55 PM | #18 |
Yeah I am glad you are going to reinforce it. I just hate to see when people try and make something that the aftermarket may have, but then you hear a horrible story about a wreck or it messed up there truck more. Yeah the search was just a quick 2 minute search this morning after I just got off a 16 hour shift. The screen was all blurry so I did not read everything.
08-18-2010, 07:27 PM | #19 |
Garage wrench
Not to hi-jack, but I just flipped the rear in my suburban and was thinking about using a notch of this style and had planned on doing some towing. Nothing really really heavy, just a smaller camper and the occasional car. Do you, or anyone, have any idea's on how to notch the frame and have it strong enough for towing. I also have some load leveling type air bags to add, if that factors into anyone advice. Thanks.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
08-19-2010, 08:25 AM | #20 | |
Low & Fast!
08-19-2010, 06:12 PM | #21 |
Garage wrench
Thanks Travis, that's what I was looking for. So if I weld in a pipe like section and box the frame over the axle and a little infront of and behind it I should be ok, right?
08-19-2010, 08:47 PM | #22 |
Low & Fast!
Ya you so be ok.
08-19-2010, 08:49 PM | #23 |
Happy to be here
Yes, it should be fine.
08-20-2010, 10:06 AM | #24 |
I used McGaughy's C-10 notches and had a buddy of mine who does welding and metal fab modify them to work on the blazer frame here's a diagram and pics!
08-20-2010, 09:56 PM | #25 |
Happy to be here
Great idea..
