back spacing
im doing a 91 camaro rearend swap and a 5 lug disk break in the front i need to know what the back spacing in with that rear end and the front
the truck is a 67 chevy stepside the lugs size is 5 x 4 3/4 and the rims are torq thrust in 20s i think i got every thing if u need more info ask me
1978 c10 stepside |
#2 | |
Re: back spacing
Re: back spacing
how would u go about measuring the back spaceing
1978 c10 stepside |
Re: back spacing
Install the rear end. Install some wheels/tires that will fit the rear end. Reverse calculate using the dimensions from those wheel/tires. A straight edge across the back lip of the wheel to the back side of the wheels mounting pad is the 'back-spacing' of the wheel. The outer-lip to inner-lip dimension minus 1" is the wheels width.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-16-2010 at 11:14 PM. |
