Old 08-16-2010, 11:37 PM   #1
my51chevyrocks
my51chevyrocks's Avatar
Truck won't start
For some reason, my truck stopped starting. It was working a week ago until I sprayed carburetor cleaner and it died in the process even though I was throttling. I am still learning. Anyone have any advice. I recorded a video.. I know. I suck.
my51chevyrocks is offline   Reply With Quote
Old 08-17-2010, 12:33 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Truck won't start
I think its the shoes. To new
dwcsr is offline   Reply With Quote
Old 08-17-2010, 11:36 AM   #3
55dude
55dude's Avatar
X2!
55dude is offline   Reply With Quote
Old 08-17-2010, 01:48 PM   #4
OrrieG
OrrieG's Avatar
Were you spraying carb cleaner down the carb when it was running? Did it back fire? 6 or v8? Start with the basics, getting fuel to carb, carb spraying fuel, spark, check timing (if it back fired might have moved the dist or hurt the timing gear or jumped the timing chain if v8, I had that happen once). Spraying cleaner down the car will lean it way out hopefully not enough to have hurt a valve. Check wiring connections if the engine was rattling around right before it died it might have shook something loose. You can always jump from the battery directly to the coil to see if that is the case. If it has an older holley carb and it back fired you may have blown out the power valve.
and those pants are way to nice to be working on the truck...
OrrieG is offline   Reply With Quote
Old 08-17-2010, 02:54 PM   #5
steve53
steve53's Avatar
before you try to start it, put the choke on a little bit and pump the throttle a couple times. then try to start it.
maybe you flooded the engine?
53 Chevy 3100 1/2 ton
1st Armored Division, OIF Veteran
steve53 is offline   Reply With Quote
Old 08-17-2010, 07:49 PM   #6
my51chevyrocks
The shoes comment was funny. I actually told a few people about it already. Anyways, thanks guys for the help. It's a V6 and I was spraying it down the carb. I always hop in my truck as soon as I get home from work and just sit in it and/or start it. LOL.
Old 08-18-2010, 12:23 AM   #7
enick72
enick72's Avatar
S-10 conversion? Like the other guys above have said first 2 most important things are fuel and fire, gotta start there before looking at anything else.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 09-21-2010, 05:19 PM   #8
my51chevyrocks
I ended up needing new plugs and new wires. I also had to replace my ignition switch. Did I tell you I was a newbie?
Old 09-22-2010, 09:50 AM   #9
mr48chev
mr48chev's Avatar
No need to, that is a bit obvious.
As Eric72 mentioned the two things you have to have are fuel and fire or spark to the plugs.
The video with the shiny shoes did show a few things and answer some questions though.
It showed that the battery was in good shape and that the starter was working fine. It also showed that the truck was trying to start but not getting the job done.
With the weather starting to get a bit cooler some of these rigs with marginal plugs, wires, cap, rotor or a carb that isn't up to par or a choke that isn't working right to not want to start as well as they did a few weeks ago.
Steve53 had a valid suggestion and point. As a lot of our younger guys grew up learning to drive vehicles with FI the old get in the truck and pump the throttle a couple of times to 1. set the choke and 2. get some fuel mixture in the intake before hitting the key isn't a habit like those of us who have driven rigs with carbs for the past 45 years have.
