Old 08-17-2010, 01:45 AM   #1
coggonobrien
need some tips for installing a TSP hei distributor
got a top street performance hei distributor. any tips for wiring/installing to a 350 in a 69 blazer 4x4? can you by a plug with pigtails at auto stores?
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 08-17-2010, 10:18 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: need some tips for installing a TSP hei distributor
Thanks,
David
I have seen the pigtails in the help section at the auto parts store but you can pull the connector with all the wire needed off a donor car at the wrecking yard too. This way you can get several feet of heavy gauge wire with it and make the connection to the fuse box without another splice in the line.
HEI's want as much voltage as you can give them and will not work well trying to power them off the old points distributor power wire. Connect it to the fuse block in a fused ignition on accessory circuit.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-17-2010, 10:59 AM   #3
coggonobrien
is the plug standard for hei distributors? also what gauge of wire do you recommend? 10awg?
Old 08-18-2010, 11:10 AM   #4
68 TT
68 TT's Avatar
All the large cap HEI's use the same plugs for power & tach feed so you can get the connector & wire from any GM vehicle from the mid 70's on up that has the large cap HEI.
The wire is probably 10 gauge but could be 12. Front wheel drive cars usually have a mile of power wire for the HEI that is easily removable from the car in one long piece. I have a section I use for diagnostic work that has about a four foot length of wire on it that came from a front wheel drive car.
Old 08-18-2010, 11:13 AM   #5
coggonobrien
ok great, anybody know of any fitment issues with the top speed performance coil on cap hei? it just looks huge compared to the originial
