found a 1972 short block 383 race new???
ok guys i really need some help here i have a 1982 chevy silverado and i hate the 305 v8 thats in it i want more hp torque etc.So my buddy has this new 72 short block 383 race new never used it comes with a w/7 quart oil pan.Thats the reason why you see the back of the inside engine smooth is because it will let the oil sink to the oil pan quicker makin it cooler.It has a oil stump he told me all this heres some picks he wants 1,300i like this cause its bigger then a 350 wich is what i wanted but this is bigger and same price as i would pay i want something around a 350 to 400 range but idk i believe is this a good deal please let me know guys ! thanks
http://i763.photobucket.com/albums/x...ebomb4/073.jpg http://i763.photobucket.com/albums/x...ebomb4/071.jpg http://i763.photobucket.com/albums/x...ebomb4/068.jpg http://i763.photobucket.com/albums/x...ebomb4/067.jpg http://i763.photobucket.com/albums/x...ebomb4/066.jpg http://i763.photobucket.com/albums/x...ebomb4/063.jpg http://i763.photobucket.com/albums/x...ebomb4/062.jpg http://i763.photobucket.com/albums/x...ebomb4/061.jpg he said he will throw in a free 10k RPM tach w/rev light for free and he spent 5k on this engine ![]() ![]() Last edited by chevymadness; 08-17-2010 at 09:01 PM. |
![]() Join Date: Dec 2008
Re: found a 1972 short block 383 race new???
tell him you will give him $900 and see what he says.
buy it...before I do
$5K in it? He's been screwed - those are hypereutectic pistons. You'll need big chambers to run pump gas, they'll be over 11:1 with typical 64cc heads and that'll put you in race gas territory. Without heads, it's probably worth about what he's asking for it. You'll need to find some 76cc chamber heads - that'll rule out Vortecs and many others. Ask him why he only polished part of the lifter valley - you'll have oil running out of all the drainback holes, not just the rear.
Pass. That's an average price and not a good deal. If it had dish or reverse dome pistons, it would be worth grabbing. Last edited by BigBlocksRule; 08-17-2010 at 09:24 PM. |
#6 | |
BAD BOW-Silverado XST
Don't be in a hurry. I found my ZZ4 on Craigslist $2,000. Paid less than that when I offered cash!
Addicted to Rust
![]() Join Date: Dec 2009
I would probably pass at 1300. 800 is more like it. 5k builds a stompin small block with some nice bits and pieces. Find out more info about the internals what kind of crank, and which rods. For him to have spent 5k they should be good quality after market. It just seems hanky. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
yea im just going to go ahead and get a overhall wich i have to and then 305 tpi the **** and mod it the hell out 305s are more full effeciant anyway and i have to choose this week what to do i dont have time to wait
#10 | |
Run an ad in your local Craiglist, look for a 4-bolt block that's set up for the factory hydraulic roller cam. I generally find 'em for about $200 with the dogbone/spider for the lifters along with the fixture for the rear seal and the oil pan. If possible, get a pair of main bearings that came out of the block, you can use them to hold the crank in place while you check for clearances and you won't mess up a new set. Ebay a Scat stroker crank, pistons are more plentiful if you get one that's externally balanced and uses 5.7" rods. Expect to pay around $250 with shipping. Scat makes some nice capscrew rods that use 3/8" capscrews, they're generally around $200 for the set. SpeedPro/Federal Mogul stroker pistons should run around $200 - $250 for the set for hypereutectics and they'll be fine for up to a 150 shot or so as long as fuel and ignition are set up correctly. Vortec heads are available for around $200/pair bare, they'll need a little work including having the guides cut down for retainer clearance and a good valve job. A few minutes work on the short turns - particularly the exhaust - will be worth 15hp or so. Another $200 should get new valves, springs, retainers, etc. Reground steel core cams are available from a lot of places, I use Delta Cams in Washington state, they're a lot cheaper than buying new. An LT4 stock cam is pretty much what we used to call an "RV" cam, more grunt that stock but not racey. If you want a bit more, the LT4 HotCam is tough to beat, it'll give you a bit of lope at idle and plenty of vacuum for brakes, etc. There are plenty of dual plane intakes available that work on the Vortec heads, shouldn't have to spend more than about $125 for one of those.
Email me direct at 81vette4speed@suddenlink.net, I'll send you some links to some of the parts sellers I've used in the past that are stand-up folks and won't screw you around. My son and I built one of these for his '99 Tahoe at the same time we rebuilt the 350 for mine. Same cam, same tune, his is a 4-door 4WD and mine is a 2-door 4WD, he outweighs me by about 800 lbs and runs off an leaves me like I'm tied to a post. There's a reason that a lot of folks build strokers - they WORK!!! |
I think your buddy messed up if he spent 5k on that and still came away with hypereutectic pistons(those pistons cost less than $300). Maybe he spent all the money on the heads? Be careful on craigslist though, my neighbor bought a shortblock from a guy that told him it had forged pistons, nitrous cam, and some other crap. After buying it and getting it home it turned out that the pistons were some cheap hypereutectics and the cam had no markings on it. The guy refused to refund the money because "that's what HIS friend told him was in the motor". So just be careful if you find a motor online.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
