![]() Join Date: Oct 2009
Instrument cluster indicators - what are these things for??
Ok, I'm admitting complete buffoonery here, but I've never seen them come on (maybe a good thing) and I have no idea what they indicate...
In the pic of a full gauge instrument cluster - what are the little lights for that I've circled in yellow? Here's why I'm asking. I've cruised around town wondering what that smell was that reminded me of some idiot smoking his parking brake by driving around town in with his parking brake on (what I moron!!)... OK, yes, it was me. So, as necessity is the mother of invention, I decided on a slick (ok, I think it's slick anyway) way of rigging up a parking brake indicator since my truck doesn't have one. And it will make up for senility, apparently. Then I noticed these lights, so wanted to rule out a factory option I just didn't know about (i.e. parking brake indicator in the gauge cluster?? or maybe they're something else). I can't find a parking brake switch anywhere (and have already started using an extra brake light switch to rig this puppy up - still in work,. maybe a thread to follow - but I think it will work out pretty good) but then I kept wondering about these 2 lights. I assume there are not blank spots for idiot lights in a full gauge cluster, but I've found weirder stuff on this truck already... (by the way, it's not my dash in the pic, but mine's the same) thanks! jocko Last edited by jocko; 08-17-2010 at 08:21 PM. |
1961 crewcab
Re: Instrument cluster indicators - what are these things for??
they are for the BIG trucks, one is an overspeed indicator, the other is for the tandem lock.
![]() and the overspeed light would be perfect for a parking brake signal!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 08-17-2010 at 08:23 PM. |
![]() Join Date: Aug 2008
I think they are for big trucks since they used the same cluster. There is lettering there, but I can't remember what they say. Shine a light behind and let us know.
There you go....
so i got curious and shined a light behind them on my truck and the left one has a bulb wired somewhere ??????(mines not big just c10)and it says tandom lock and the one on the right says overdrive and is empty no bulb or wiring !
Most excellent gents - thanks so much, that is what i needed to know. The plot thickens... maybe a better idea to use one of those, and re-do the lettering or something than my first plan.... (was planning on mounting an "old looking" LED that is approx 1/2 inch in diameter with an old faded aluminum trim ring - and hooking that up to be my "old school brake light" indicator, but now the wheels are turning - might be a better way!
Thanks |
#7 | |
1961 crewcab
the overspeed wire will go to a little junction box in your speedo cable. ...re read your post.... you'll have to chase the wire, could be as simple as someone changing the bulb in the cluster, and plugging it in in the wrong spot.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 08-17-2010 at 08:44 PM. |
re read post the tandomlock has bulb and overspeed has nothing ! i was thinking the same thing chase down wire see where it goes .....
I had my shift light wired to the "overspeed" socket and an oil pressure warning light in the "tandem lock" spot.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Have my Overspeed hooked up to the dash lights, an incentive to slow down.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I think making the one on the right an oil pressure warning light, and the one on the left an overheating warning light would be good.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 07-02-2012 at 02:33 PM. |
I now have these lights lit up on my dash also. They weren't before i went in and cleaned up the cluster. In my haste to put it back together again, i neglected to put in two little green cardboard tubes. These were just long enough to go from behind the plastic face plate, down to the bottom of the cluster. It kept the light from getting to these. I still have the tubes and one of these days i might put them back in. I just don't feel like removing the whole cluster and with mine having a manual choke, i need to rethread that through there again. I've thought about putting a couple of stickers on them for the time being.
Members i've met: LiLRed66 |
#13 |
1961 crewcab
that manual choke on a 456, did you remove the knob, and then remove the bezel? that is the easy way, which I figured out after doing one the hard way- pulling the knob and cable out of the housing, and the trying to push it back through the housing
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#14 | |
Thanks, Jonzcustomshop.
#15 |
On my 66 I rewired the whole truck and made the overspeed light up when my headlights are on because i have a habit of leaving my headlights on and not noticing in the early morning drives to work, The light that illuminates the regular dash gauge cluster is had to see in the morning and you can really see when the overspeed light is lit up....its kinda like my highbeam warning light except for my headlights
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#16 | |
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#17 |
Ha! Can't believe this thread is still alive - posted what I ended up doing a long time ago, but never put a link in this thread, here it is: http://67-72chevytrucks.com/vboard/s...d.php?t=419932
#18 |
What I do instead of starting a new thread on a topic, I search, and then post in a relevant thread.
![]() Posted via Mobile Device
#19 |
![]() Join Date: Jun 2011
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
