Old 08-17-2010, 08:52 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Cut it, beat it or Replace it lowered front end dust shield
I dropped the front end of my truck and discovered tonight it was not my brakes dragging but my rotor is rubbing against the dust shield
See the attached photo for the area of concern.
Has anyone else ran into this situation?
These are ece drop spindles
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 08-17-2010, 09:15 PM   #2
huero
1969 Short, Fleet, and Beat
huero's Avatar
Re: Cut it, beat it or Replace it lowered front end dust shield
Bend that baby back.
huero is offline   Reply With Quote
Old 08-17-2010, 10:06 PM   #3
Sammy
I don't think those dust shields are bent right. I don't recall that flat spot on my stock shields. You sure those are not a later model? I will have to take a look at mine tomorrow in the daylight.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-17-2010, 10:38 PM   #4
swierker
swierker's Avatar
Are those ECE dust shields? The ones I got from them don't have that cut out in them.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 08-18-2010, 01:48 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
a big hammer will solve all of your problems....or at least this one.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
