08-17-2010, 09:38 PM | #1 |
Lowering my stock lwb
I plan on lowering my 71 lwb using 2 1/2 lowering spindles but I'm not sure what to use for the rear. Sould I use 2 inch lowering blocks or go for 2 inch lowered springs. Now, I do use my truck going to the dump or hauling stuff. I want to keeep the load from sagging the bed. I do take it cars shows aroung here and keep it in good shape but I sometimes have to use it otherwise. So any help will be greafull. It is a stock height.
08-17-2010, 10:05 PM | #2 |
Nothing to see here.....
Re: Lowering my stock lwb
biga,
I would definitely go springs. they are cheap. plus since you want to keep the load carrying characteristics of the truck, new springs compared to the oems (for the most part) are stiffer and contain higher spring rates.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-18-2010, 09:01 PM | #3 |
Thanks, that helps a lot. I can now understand why springs would be better. Cost a little more but will get the job done.
08-18-2010, 09:16 PM | #4 |
X2
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-18-2010, 09:28 PM | #5 |
Go with the springs!
A USED TRUCK IS A LOVED TRUCK! |
08-19-2010, 02:35 AM | #6 |
That’s 2 inches closer to the ground them U bolts will hang too if using blocks, if your concerned about any clearance issue depending on where you drive that rig. So go with springs IMHO.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
08-19-2010, 08:43 AM | #7 |
trail arm bushings and panhard bar bushings should b done too as well as the ball joints tierod ends etc// that way you get a greater ride quality
08-19-2010, 10:18 AM | #8 |
Active Member
Love the look of a low lwb... Maybe even more than I do a low swb.
Post some pics after you do it. |
08-19-2010, 12:29 PM | #9 |
Old member
I lowered mine with springs then added the helper air bag! Man what a great ride it has now no more botoming out with any load.
Ran the lines back to the tag area and use them as my bolts for the tag.
