Old 08-17-2010, 09:50 PM   #1
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Grinding sound from rear end when turning
Ok WTF! New rear end with locker...opened the diff drain the oil and did not see anything wrong with the inside! Jacked it up turn the wheels no grinding or tension when turning wheels!????! it happends at low and high speeds! Does anyone have any idea what the hell this is? Im guessing it mite be my axle bearings????
GGinferno is offline   Reply With Quote
Old 08-17-2010, 09:52 PM   #2
blackedoutharley
Re: Grinding sound from rear end when turning
Is it a true "locker" or a spool?
They are known to make noises on turns depending on the application.
blackedoutharley is offline   Reply With Quote
Old 08-17-2010, 10:05 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Does it require any certain additives?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-17-2010, 10:10 PM   #4
GGinferno
GGinferno's Avatar
I have a auburn locker! but the grinding is so bad when i turn slow it shakes the whole bed!
Old 08-17-2010, 10:12 PM   #5
GGinferno
GGinferno's Avatar
It has had the rear end for about 1 year! with no problems till now! no more donuts and burnouts! F%@k!!!!
Old 08-17-2010, 10:21 PM   #6
glendale
glendale's Avatar
that sucks dude. at least mine is just old and worn out.
glendale is offline   Reply With Quote
Old 08-17-2010, 11:14 PM   #7
Captainfab
60-66 Nut
I've heard that the Auburn's don't last as long as other types. The bad part is I don't think they are rebuildable. You might see if a mod will move this to 'Engine and drivetrain' for more replies and a better idea what's going on.
Old 08-20-2010, 11:13 PM   #8
GGinferno
GGinferno's Avatar
Thanks guys! got it fixed! changed the oil to 80W90 and added some LSD additives and we are rolling!!!! God damm lockers! never had this problem with my rock crawler!
Old 08-20-2010, 11:17 PM   #9
Rich 5150 69
Rich 5150 69's Avatar
I know we talked about it at the BBQ, glad you got it fiquired out....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-20-2010, 11:42 PM   #10
GGinferno
GGinferno's Avatar
Yup! the thing that is sensitive on these lockers is the clutches! you dont have the right formula and they scream at you! almost like a women! lol!
