08-17-2010, 11:21 PM | #1 |
Bags Vs. Coils
Hey guys,
I have a 72 LWB C-10, I'm in the process of lowering my truck and need to decide on a conventional 4/6 lowering kit or putting bags on the rear end. I want to be able to do some heavy duty towing and I hear bags are a great way to lower the rear of your truck while maintaining towability. Can anyone give me some feedback on how the ride is with bags? Should I just go bags all around if I do? I have heard the ride with bags can be stiff and jumpy. Anyone have any feedback? Also, if I go the conventional route what would be the best kit to go with? I am thinking a 4/6 drop, but I want the truck to be as close to level as possible. I am not a huge fan of having a rake. A small, very small one is acceptable but I am leaning toward none at all. Is a 4/6 even the right kit to use? I don't want to have to notch the frame. Can I get away with putting on larger tires? Anything would help guys... Thanks in advance. P.S. As you can see, the ass end is just a bit higher than level. I just want to drop it a little bit. Any suggestions? Brian |
08-17-2010, 11:33 PM | #2 |
Nothing to see here.....
Re: Bags Vs. Coils
just my .02
I had both a minimum and a huge conventional drop and now bags. I can honestly say that the bags ride better than any setup I've ever had. bags are also adjustable to what your doing at the time be it towing or show. however a full air ride system is not exactly cheap. plan on at least 1k to 2k, depending on how you set it up. springs are stiffer, but more economical and in some cases, reliable. lastly, your truck should be approx 2" higher in the rear than it is the front if it still has the original suspension on it. a 4/6 drop should put you even all the way around, but with a noticably lowered stance.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-18-2010, 01:33 AM | #3 |
Re: Bags Vs. Coils
I have coil drop (actually more like 5/7) but will probably put bags (or helper bags) on the back (just use shraeder valve for occasion heavy load).
With coils I don't worry about front end alignment changes with different pressures (don't know how much of an issue that really is). The rear springs are soft for a good ride and won't carry a load of any significant weight. No air compressor etc... is a plus. |
08-18-2010, 01:40 AM | #4 |
Big Red - Now its a SWB!
Re: Bags Vs. Coils
If you plan on hauling then I would say put bags in back, you can do like suggested and use tire valves then just air up for heavy duty. otherwise anytime you haul you will lean back.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
08-18-2010, 03:49 AM | #5 |
Re: Bags Vs. Coils
i agree with tcb the ride is much better on air... think about it just about every 18 wheeler on the road now days has air ride suspension
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
08-18-2010, 09:29 AM | #6 |
Re: Bags Vs. Coils
Air ride rides smooth and with a sway bar, it handles well through the corners. Adjustable with the ability to haul. I pieced mine together and I spent $1500 with an 8 valve setup.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
