Old 08-18-2010, 12:09 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
inner fenderwell idea...?...
I was thinking of this the other day.
I wonder if a set of inner fenderwells could be fabbed up to fit inside what is currently in our trucks?
kind of like the big round ones that are used on 67-72, or the 73-87's.
our inner fenderwells end high up on the cowl, which leaves the cowl to act as the fender well.
this exposes the fender brace and corner of the cowl to the elements, which is probably another reason rust is so bad in these areas.
the thing that got me thinking about it is my tires like to pick and throw rocks, when the rock hits the floorboard/toe panel, it usually startles me , and scares the kids... I was thinking a inner fender would cut down on that, and then got to thinking of the rust issues too...
anyone already done ths?
Old 08-18-2010, 06:29 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: inner fenderwell idea...?...
1: Seen a picture where a guy took a sheet of rubber and followed the contour of the fender opening. He had it attached by plastic plugs to the outer fender lip and inside fender.
2: Sprayed mine with Line X, we'll see how that does.
Old 08-18-2010, 07:51 AM   #3
lakeroadster
Jon,
I am with ya. I was wondering if a guy could start with a trailer fender and then fab additional pieces to tie into the stock inner fenderwell. Entire deal could then bolt in.
In addition to the cowl area this would also help keep mud and crud out of the front headlight area.
lakeroadster is offline   Reply With Quote
Old 08-18-2010, 08:52 AM   #4
jonzcustomshop
1961 crewcab
take a look at the inners on your 69 camaro, I have a 70, and they have a nice round one that might fit up in there, they are real light tin, so easy to fab with....
Old 08-18-2010, 10:48 AM   #5
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: inner fenderwell idea...?...
John,
This has been in my plans for a while now. When I get my truck back on the road I would like to have this done. My father and I made a templet , but not sure if we will use it. It has been hard to find trucks online in our years to go by. But this is what I found so far, and will be similar to what I will be doing. See below.
red rumbler's Truck:
My truck:
Guys with no front inner fenderwells.. Need pics
http://67-72chevytrucks.com/vboard/s...d.php?t=285142
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-19-2010, 12:02 AM   #6
Captainfab
60-66 Nut
I've had those same thoughts Jon, but I haven't done anything with it other than acquire a couple sets of '67-'72 and '73-'87 inner fenders. Let us know if you get something figured out.
Old 07-16-2012, 06:14 PM   #7
wilkinst
I know I'm resurrecting this thread but I've thought about lining my wheel wells with plastic for awhile now. Wondered if anyone had made any headway? I think I remember someone buying some cheap plastic sleds that could be cut and molded to fit. I'd like to have the lining extend back and under the cab floor (from the edge of the inner rocker to the cab support).
Ideas?
wilkinst is offline   Reply With Quote
Old 07-16-2012, 07:26 PM   #8
1Bad62Pro/Street
Arrow Re: inner fenderwell idea...?...
Nothing done to mine yet. Got some ideas in my head from car shows I've seen.
More threads:
http://67-72chevytrucks.com/vboard/s....php?p=4566921
1960-1966 Hand Fabbed Inner Fenderwells.. Need pics
http://67-72chevytrucks.com/vboard/s....php?p=4566429
Racing and high performance (trucks haulin more than hay)
http://67-72chevytrucks.com/vboard/s...80#post4565880
Old 07-16-2012, 08:00 PM   #9
lucifer
lucifer's Avatar
Don't see why you couldn't use plastic? I made plastics liners for the rears on my stepside so I wouldn't get those spider cracks from rocks thrown up from the tires.
Just saying
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 07-16-2012, 09:11 PM   #10
wilkinst
Where'd you get the plastic? What thickness did you use?
Old 07-16-2012, 09:13 PM   #11
1Bad62Pro/Street
These were on a Nova that I was looking at in the attached images and the other images I found online.
Been thinking about going this route:
http://www.cachassisworks.com
Old 07-17-2012, 06:29 AM   #12
lucifer
lucifer's Avatar
Cool Re: inner fenderwell idea...?...
Summit sells plastic in rolls. They are approx .070 thick X 10 ft. There are other options from simmut but thats what I used. Easy to work with.
Old 07-19-2012, 10:30 AM   #13
piratexpress1369a
piratexpress1369a's Avatar
did you use the plastic in the front fenders as well? do you have a pic of it ?
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 07-23-2012, 06:35 PM   #14
wilkinst
0.07" seems a little thin...but so far that's the best idea I've seen. Thanks!
