Old 08-18-2010, 09:27 AM   #1
shaneschevys
Its always something!
shaneschevys's Avatar
floor getting wet in 99 suburban
My father in law recently bought a 99 suburban and the passenger floor is getting wet. I changed the heater core and it didnt stop it. When the truck sits with the a/c on it doesnt leave alot of condensation. We have not got much rain here lately so I know it cant be leaking from the rain. Is it possible for the condensation from the a/c to be leaking into the floor? I cant find any evidence of this. Any help would be appreciated.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 08-18-2010, 09:30 AM   #2
danomano
Re: floor getting wet in 99 suburban
Yes the drain hole could be blocked.
danomano is offline   Reply With Quote
Old 08-18-2010, 09:34 AM   #3
clinebarger
Check to see if the drain for the evaporator is clear. Its right below the heater hoses on the firewall. On a humid day like today it should drip alot of water with the A/C on.
clinebarger is offline   Reply With Quote
Old 08-18-2010, 09:41 AM   #4
shaneschevys
It does drip some but not like it should. The rubber elbow was missing from the drain so I rigged a short piece of hose to replace it. I will call him and get him to check it to see if it is clogged up.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 08-18-2010, 10:30 AM   #5
sparkydog
sparkydog's Avatar
Another possibility is that the cowl drain is blocked on the pass side. This is supposed to dump water out the firewall and into the void between the fender and the wheel skirt. If it blocks up enough then you can get a little lake going up in your cowl and this will spill into the HVAC blower intake and the leak off the bottom of the blower and onto the pass floor.
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 08-19-2010, 09:10 PM   #6
MattA
MattA's Avatar
You probably fixed it with the hose. Without a drain elbow the condensation will drain right back into the cab on these trucks.
MattA is offline   Reply With Quote
Old 10-08-2011, 04:37 PM   #7
Cooper33
Cooper33's Avatar
have any pics? i have the same problem with 2007 tahoe.
Brad
67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426
89 Ford Bronco
92 Suzuki Sidekick
94 Kawasaki Vulcan 750
06 Honda Aquatrax
Cooper33 is offline   Reply With Quote
