Old 08-18-2010, 10:06 AM   #1
manimal
manimal's Avatar
Exclamation need help with my wife's 'burb...please
Ok, last friday my wife was driving her '89 suburban(2wd,454 TBI,th400) and it would just shut off,and have a hard time restarting. You can no longer hear the fuel pump priming(usually ran for like 2 seconds then shut off),the the car would start. Now it seems to crank and crank then finally start,but run for a few minutes and shut off. After the initial start,it will start(hard) run for about 15 seconds and shut off. I have replaced the fuel pump(in tank) and filter, the coil and distributor module check out just fine. I have swapped around relays, but now I am stumped. Can anyone please help me out? Thanks
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 08-18-2010, 10:55 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: need help with my wife's 'burb...please
fuel pressure regulator. Same thing happened to my old 87 astro van. Got a rebuild kit for the tbi unit, installed it and the thing ran as good as new.
Regulator is mounted on the top of the tbi unit.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 08-18-2010, 11:17 AM   #3
dropd80s
dropd80s's Avatar
Also might want to make sure you have power to the tank and to the pump. I bought a 91 sub that would not start, the terminals on the in side of the tank on the bottom side of the pump/sending unit assembly were corroded just enough so the pump couldn't get any juice.
dropd80s is offline   Reply With Quote
