Old 02-22-2003, 05:45 PM   #1
phantom dually
Project92 SWB stepside
phantom dually's Avatar
rear drum to disc conversion kit.
I want to convert drums to disc in the rear. I hace seen brackets kits sold on ebay that say to use a lincoln 77 rear rotor and a camaro 82-92 caliper. Has anyone done this??? If so let me know what you think!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-28-2003, 01:05 AM   #2
bagged81
Signals in the bumper.
bagged81's Avatar
ttt
I would like to convert my 81 to rear discs also.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 02-28-2003, 01:09 AM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
www.StainlessSteelBrakes.com is the place to order from. Their kit is expensive, but remember---You get what you pay for!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 02-28-2003, 01:45 PM   #4
Frank_Zeller
Frank_Zeller's Avatar
I got the 1979 Seville rear disc brake set up to install on my truck Rotors are 5x5. Hoping for the best.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 02-28-2003, 09:11 PM   #5
phantom dually
To update all!! I just bought brackets from a seller at e bay. I put them on to see if they would fit and well they did BUT. I had to have my axle flanges turned down a 1/4" for the rear rotors to go on. I used a rear disc brake rotor 5x5 from a 1977 lincoln continental. You can use a front caliper for a 82-92 camaro rs without the 1LE brake package. I paid $30 to have my axles turned down and now everythingfits great. I gave $90 for the brackets and $30 a piece for the new calipers. Then I bought a performance slotted rotor from pureperformance.com for $90 each. I have a total of $330-$350 into my conversion and they are going to look great. For the brackets call Steeltech Solutions at 618-997-4238.
Old 02-28-2003, 10:54 PM   #6
turmoline
Don't forget to change out that old master cylinder for the four wheel disc version as well.
turmoline is offline   Reply With Quote
Old 03-01-2003, 12:57 AM   #7
phantom dually
I havent got that far but what should i use?? YR MAKE MODEL??
Old 03-01-2003, 04:50 PM   #8
turmoline
I bought mine from classic perfomance products. www.classicperform.com
Old 03-01-2003, 10:05 PM   #9
Blue Beard
Blue Beard's Avatar
Was on GMC Pauls site yesterday.
One of his new items was the rear disc brake kit for 5 or 6 lug trucks with the 10-12 bolt..........
item
149693 5 lug rear
149694 6 lug rear
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-02-2003, 11:34 PM   #10
79GMC454C35
Brake kits for EVERYTHING
There is a small place south of Denver that makes VERY nice kits. They are not much money. They can help guide you the least expensive way to go. You can get the kit in any stage so you can round up your own rotors & calipers if you want. I have dealt with them alot & they are GREAT! Talk to Skip & tell him Troy from Phoenix sent you.http://www.tsmmfg.com/Front_Disc_Brakes_others.htm
79GMC454C35 is offline   Reply With Quote
Old 03-03-2003, 06:35 PM   #11
rin68
rin68's Avatar
phantom,
how did (if at all) did this kit change wheel backspacing-related measurements? also does this setup have a parking brake or allow for one to be installed later? thanks
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 03-03-2003, 11:16 PM   #12
phantom dually
You can install rear calipers from a caddy but they are not cheap. They come with a built in parking brake as do rear camaro calipers. I did not use one as my truck is not a daily driver. As far as back spacing is concerned it did not change a 1/4 inch if at all. I am ordering wheels and they will be made to specs from this setup. Thanks
Old 03-08-2003, 10:18 PM   #13
nate68
master cylinder: mid 70's corvette
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-08-2003, 10:41 PM   #14
79GMC454C35
as I remember the TSM kit changes the offset by 1/8". You have the option of using calipers like you have on the front of your truck or I think Toranado E-Brake calipers. E-Brake calipers are about 4 times as much as non e-brake calipers. Buy "loaded" calipers from Autozone or NAPA & they come with ALL pins, pads, seals that you need.
