Old 08-18-2010, 02:51 PM   #1
dbmx66
how to i get this off?
if you take your brake booster off, the piece that has the 6 studs on it, it looks kinda goofy, i dont really know how to explain it. but is it a piece of the cab or can it be removed? thanks
dbmx66 is offline   Reply With Quote
Old 08-18-2010, 03:04 PM   #2
cableguy0
Re: how to i get this off?
I believe that piece is spot welded. It could be removed but you would want to reinforce the cab in that area to add another master cylinder. the single wall steel of the firewall will flex a ton without support.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-18-2010, 03:15 PM   #3
dbmx66
i have a piece of 1/4 inch aluminum plate im gonna put on.
do you wknow where its spot welded? i can seem to find the spots?
Old 08-18-2010, 03:26 PM   #4
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
take some sand paper and run under where the steering collum exits and on the left side on it thats where the spot welds are if i remember correctly
and the rest is just glued on with body sealer
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 08-18-2010, 10:17 PM   #5
dbmx66
okay, ill try that, thanks
Old 08-18-2010, 10:51 PM   #6
joe231
joe231's Avatar
The studs are on the brake pedal support/assembly above the column. They aren't attached to the support piece on the firewall. You can remove it by removing the column and the booster.
I can get pics of the firewall without the support/assembly attached to it.
Or ar you just talking about the re-enforcement plate on the firewall?
CHEVY ONLY
Old 08-18-2010, 11:12 PM   #7
dbmx66
just the reinforcement plat, im keep the brake/ column support thing.
Old 08-24-2010, 11:27 PM   #8
dbmx66
well i found out the hardway, like usual
for anyone wanting to remove this, take your time and find all the spotwelds before ripping it along with half your firewall out
