08-18-2010, 02:58 PM | #1 |
15 inch wheels with front disk brakes, Will it work?
I will be putting rotors and disk brake calapers from a 73 C10 on the front of my 65, will 15 inch wheels fit over the calapers?
Thanks |
08-18-2010, 03:31 PM | #2 |
Never Ending Projects
Re: 15 inch wheels with front disk brakes, Will it work?
As long as the 15" wheels were designed for disc brakes, no problem. Some factory wheels that were built for drum can interfer with the caliper.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-18-2010, 05:10 PM | #3 |
Intentionally Left Blank
I have 15x8 inch wheels with the Early Classic Enterprises disc brake kit and I've had no problems.---jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
08-18-2010, 05:49 PM | #4 |
excellent question and here's a follow-on:
Same problem I had with a 55 first series - I wanted to run stock steel wheels but all disk brake kits would result in interference. Disk kit dealers all said a spacer (I forget the size, but it was slim) would resolve the problem. Does that hold true for 60-66? In other words - for those that have run into this problem, exactly where does the interference with the caliper occur for stock steelies? (a diameter or depth/offset issue?) Thanks, jocko |
08-18-2010, 05:55 PM | #5 |
Sorry, I forgot to mention that I have after market aluminum wheels.
08-18-2010, 06:29 PM | #6 |
Senior Enthusiast
The caliper interference occurs with the tapered backside of the pre-disc brake wheels. Almost all steel wheels prior to disc brake had a cylinder shaped front side and a conical/tapered rear shape to the rim, for ease of installing the tire. When discs came along, they simply made the back of the wheel cylinder shaped like the front, providing more clearance between the back of the wheel rim and the caliper.
Although the photo below is an early Radir mag, it uses an original pre-disc brake rim. I've marked the tapered area that normally causes the interference: |
08-18-2010, 06:48 PM | #7 |
now i get it. great explanation markeb01, thanks very much.
08-18-2010, 07:15 PM | #8 |
I just made a 1/4" spacer and it works just fine for the last 16 or 17 years and I am running 8 lug on my 4 x 4
ron |
08-18-2010, 09:03 PM | #9 |
are 8 lug whls 15" or 16"?
08-18-2010, 09:44 PM | #10 |
can be either or 17"
By rondavid at 2010-08-18 an original 15"-8lug' I did use a later 15 x 8 white spoke wheel ron Last edited by padresag; 08-19-2010 at 12:33 AM. |
08-19-2010, 08:47 AM | #11 |
meowMEOWmeowMEOW
I have 15 in Mickey Thompson aluminum wheels and they clear my manual front discs fine.
08-19-2010, 10:10 AM | #12 |
1965 Chevy C10, 2005 4.8L/4l60
I have 80's GM Truck 15x8 Rallye wheels on my 65. I have a 72 disc front suspension
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 08-19-2010 at 10:11 AM. |
