08-18-2010, 03:52 PM | #1 |
To Haul or Not to Haul
Alright, I need some expert advice on this one. I want to pick up a pallet of sod that they're estimating weighs in around 800-1000lbs. Last year, I hauled a yard of topsoil in it and it was riding so low, I was $hitting bricks the whole way home. Here's the particulars on the truck.
1/2 ton Lowered 4" in the rear with ECE springs and KYB shocks BFG Radials all around What do you think? |
08-18-2010, 04:26 PM | #2 |
Re: To Haul or Not to Haul
1 yard of topsoil will weigh around 1500 pounds. Either go get it, or make two trips !
08-18-2010, 05:02 PM | #3 |
i had the suspension bottomed out with a few model Tbodies 6flathead engines with misc other parts. drove her almost a thousand miles from the midwest to long island//and you're frettin about drivin how many miles??
08-18-2010, 05:08 PM | #4 |
Meh, I wouldn't worry about it. I've hauled that much mulch before with absolutely no troubles, and mine's a 1/2 ton, too. Heck, I don't even have discs up front, nor power brakes. You should be fine.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
08-18-2010, 05:16 PM | #5 |
If you were $hittin bricks that should have lightin the load.
I'm not as good as I once was, But I'm as good once as I ever was. |
08-18-2010, 07:38 PM | #6 |
08-18-2010, 08:23 PM | #7 |
See, that's why I don't understand lowering a truck. You have a half ton truck and your afraid of hauling a half ton.
08-18-2010, 08:50 PM | #8 |
i can haul a ton in my truck and its stock suspension and i was fine
08-18-2010, 09:51 PM | #9 |
if your not sitting on the bump stops you won't have anything to worry about and if you are on the bump stops then you won't have to worry about bottoming out
shouldn't be that big of a deal but if your still worrying try to get a pallet when its a little dryer and just water it as soon as you can |
08-18-2010, 10:55 PM | #10 |
It'll be fine, toss a spacer between the axle and the bump stop so you arent completely bottomed out and take it easy. I hauled 1ton in my 75 Chevy C10 to the scrap yard without a problem, just a lil light on the steering, lol!
08-18-2010, 11:14 PM | #11 |
While I have a 4x4, it's still a half tonner and I load all kinds of weight in it. I just dumped ~1000 pounds of scrap metal out of it, I get 1500-2000 pounds of split oak every year, and I have been known to load a dozen or more kegs of beer in it( around 2200lbs). Pump your tires up all the way, make sure the brakes are good and you will be fine. Just make sure you position the weight correctly.
08-18-2010, 11:24 PM | #12 |
i have a 68 4x4 stock everything and i just hauled 1,455lbs 750km, over two mountain passes lol. looks like you will be laying sod my friend, no getting out of it with "my truck can't handle the weight lol. good luck!
[B][/B] James 68 GMC SHORT FLEET 4x4 83 Dodge short fleet 2x4 2000 Civic SI |
08-19-2010, 12:20 AM | #13 | |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
08-19-2010, 12:27 AM | #14 |
I agree to a point. If it's purely a show/pleasure vehicle than I think they're gorgeous trucks bagged. But for those that actually USE there truck, I think a drop is counter-productive. Of course I'll take a lifted truck over a slammed truck any day of the week.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
08-19-2010, 07:44 AM | #15 | ||
Thanks fellas! |
08-19-2010, 09:49 PM | #16 |
With factory suspension, GVWR is 5000lbs. Empty weight approx.3500lbs. Which leads to load capacity of approx.1500lbs. Without factory suspension? Tire capacity is also a determining factor.
08-19-2010, 10:08 PM | #17 |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-19-2010, 11:38 PM | #18 |
I'm figurin on 800lbs so it should be fine. I'll just have them put it as close to the cab as they can so it's not sitting over the rear too much.
08-19-2010, 11:49 PM | #19 |
That's why they make trailers to tow behind the truck. Actually around here I see guys with lowrider trucks hauling some pretty heavy loads all the time and not batting an eye. If the tires don't rub and you have bump stops to absorb some of the bounce it may be rough on the axle or frame though.
