Old 08-18-2010, 04:01 PM   #1
6768chevylover
6768chevylover's Avatar
Lower control arm nut
Does any one know the torque spec for a Lower Control Arm nuts on each side of the shaft? I had bought new lower arms and I have no clue what to torque them at. thanks-mike
6768chevylover is offline   Reply With Quote
Old 08-18-2010, 10:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lower control arm nut
I did a search and came up with this.
http://67-72chevytrucks.com/vboard/s...t=a-arm+torque
I know for 67-68 in the service manual, the shaft bushing bolts are for the upper new is 160ft.lb, replacement 95ft. Lb. And lower is new 280ft. Lb, replacement 135ft. Lb.
But YOU actually answered this thread.^^^ (5-6-2009)
Is this info not correct?
Keith
Convert to disc brakes.
Old 08-20-2010, 08:05 AM   #3
6768chevylover
Im questioning it cause my front suspension has no flex. i can jump on the front end and no bounce and even when I jack the front up on the lower a arm it wont flex up and down. I think its the torque spec.
Old 08-20-2010, 04:01 PM   #4
raycow
Is it possible that you don't have the control arm centered on the shaft, and consequently ran out of threads at one end?
Ray
raycow is offline   Reply With Quote
