Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Bench Seat converted into Bucket Seat
I have two bench seats, both need to be re-covered, so the thought is to cut them down to the size of a bucket seat. Has anyone attempted this? They would be installed in my 4WD project.
Suburban & Panel truck seat floor dimensions would be nice.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 08-18-2010 at 06:22 PM. |
![]() Join Date: May 2007
Re: Bench Seat converted into Bucket Seat
If it can be done it would be you who could.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Do it Aerotruck.... you know you want to!
1961 crewcab
dinos crew has coach built bench/buckets
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Real Greasers use "Murray's"
Now I believe the Panel truck seat had a steel panel backing and were wider than the Suburban Bucket that folded against the dash?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
18 5/8" outside to outside is the measure of a panel folding seat
ron |
Well, cut down the bench by 41 3/4" to make a bucket seat about 18" wide. Need to weld it up now. One drawback, only one seat track lock will be operable as they are to close together to link them. The passenger side lock lever pulls from the bottom via a connecting wire, and the drivers side pulls from the top. I cut where the triangular plates in the front corners of the seat bottom end. That determined the dimension.
It's an illness I tell you!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-17-2010 at 07:03 PM. |
#10 | |
With the upholstery on the frame it will be a bit wider than 18". The Suburban/ Panel seat is 18 5/8 " wide as padresag mentioned. I've never sat in one so I don't know if it was uncomfortable. There's also driving with a seat that's off center of the steering wheel, if I use the original mounting position.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-18-2010 at 06:27 AM. |
