Old 08-19-2010, 11:03 AM   #1
Hanky
Hanky's Avatar
Wheel Lock Removal
Well I was up at the shop starting to tear more of the 62 down, and when I went to remove the hub caps what do I find? Low and behold, wheel locks. Guess what folks, I dont have the key, and it is knowhere to be found. The man I bought her from has no clue either. These are on the original 6 lug wheels. Does anyone have any tips on how to get them off? Thanks in advance for any ideas or imput.
Hanky
Hanky is offline   Reply With Quote
Old 08-19-2010, 11:07 AM   #2
63 & 64 Bowties
and a few others
Re: Wheel Lock Removal
I've done it in the past with a good chisel. The keyword here is GOOD chisel, not a Chinese one. Start a cut on the upper edge applying force counter-clockwise and it will unscrew. A quality chisel with a sharp edge will cut into the lugnut.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-19-2010, 11:25 AM   #3
Hanky
Hanky's Avatar
Suggestions on locating a Quality Chisel? Home Depot...Sears?? Thanks for the tip. Anyone else?
Old 08-19-2010, 11:38 AM   #4
NCD1966
NCD1966's Avatar
I bought a lock lug remover from the local parts store. (pep boys)
Oreilly and others should have them. I paid about 27 buck and you get 2 different sizes.
Worked out great for me. My locking lugs where almost to tall for the remover but a few hard hits from a good size hammer, then put your impact wrench full on reverse and your done.
looks like this
http://ecx.images-amazon.com/images/...500_AA280_.gif
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 08-19-2010, 04:08 PM   #5
raycow
Some of the tire stores around here use an ordinary socket wrench with a taper ground on the inside. They just hammer it onto the lock until it is wedged tightly and unscrew it.
Ray
raycow is offline   Reply With Quote
Old 08-19-2010, 04:21 PM   #6
steverino66
I've used the chisel method, but I've also done it by filing a flat spot on the lug and locking vise grips on it (necessity being the mother of invention) - if there's room in the wheel
steverino66 is offline   Reply With Quote
Old 08-19-2010, 06:23 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
or if you have a welder, you could weld a lug nut to it, and wrench it off...
Old 08-19-2010, 06:26 PM   #8
jocko
jocko's Avatar
now THAT is a good idea jonzcustomshop!
Kinda unnerving that you can buy a tool for $27 to remove wheel locks from the local pep boys... Pretty much defeats the purpose.
Old 08-19-2010, 08:33 PM   #9
62 Longbed
62 Longbed's Avatar
I've always just used a old metric socket six point or 12 point that will start to slip on , then hit it a few times till its lodged on then take a breaker bar or 1/2 drive rachet w/ extension or air gun and zip it off ... Remember your wheel nuts will always be on tighter than your wheel locks .. Hope this helps ...
62 Longbed is offline   Reply With Quote
Old 08-19-2010, 09:49 PM   #10
protrash64
Resistance is Futile
protrash64's Avatar
Yep.....removed a couple sets by hammering on an impact socket and buzzing them off in reverse.......not hard. Just be careful if you have nice wheels.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-19-2010, 10:03 PM   #11
72lb4x4
I recently bought a car w/ locks and wasted alot of time buying remover sockets that didn't fit in the hole in the mags, and asking a few tire shops. I finally spent 5 min taking them off with a chisel and BFH. The locks were pretty crappy steel.
Any name brand, large (about 1/2" to 3/4" wide) cold chisel should be fine.
72lb4x4 is offline   Reply With Quote
Old 08-19-2010, 10:17 PM   #12
mrh33916
Project '67 454
mrh33916's Avatar
Yep I've done it, works great,
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 08-20-2010, 08:58 AM   #13
Hanky
Hanky's Avatar
Thanks for all the suggestions. I will be cranking on the tomorrow.
Hanky
Old 10-12-2010, 12:01 AM   #14
slepysal
slepysal's Avatar
this has worked for me before too
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-13-2010, 11:04 AM   #15
Chevy Fleetside
Chevy Fleetside's Avatar
That is how we did it at the tire shop also.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
