08-19-2010, 02:42 PM | #1 |
700R4 to a mid 60's SBC
Is there any reason why a 700r4 wouldn't bolt up to an older SBC?
08-19-2010, 04:30 PM | #2 |
Re: 700R4 to a mid 60's SBC
Nope, works fine - bolted one to a 60s model 350 in my El Camino
08-19-2010, 05:52 PM | #3 |
08-19-2010, 06:32 PM | #4 |
Just bolted one to my 327 this last weekend.. check the pics in my sig
My build thread: '66 Chevy |
08-19-2010, 09:58 PM | #5 |
Resistance is Futile
You need a dual pattern flexplate because the newer torque convertor will be roughly a 1/4'' off the old pattern.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-20-2010, 12:31 AM | #6 |
60-66 Nut
Good to know, I didn't realize that....thanks
08-20-2010, 01:36 AM | #7 |
Redneck Hillbilly
+1. This should be the only thing that needs to be changed on the engine for the swap to a 700R4. Of course the trans mount and crossmember will be different, and the driveshaft may need to be altered as well. I have heard rumors of interferance with factory exhaust on some applications, but have yet to have that become an issue myself.
08-20-2010, 02:05 AM | #8 |
So if I was to go down to napa nad tell them I needed a particular flex plate, what would I tell them? What year etc? Thanks for the help
08-20-2010, 02:13 AM | #9 |
Redneck Hillbilly
Tell them a dual pattern Chevy small block flex plate. If they look at you funny, tell them a flexplate for a 1985 Chevy 1/2 ton 2WD SBC automatic (any early to mid 80's vehicle with the 4speed automatic trans will work though).
08-20-2010, 02:27 AM | #10 |
Redneck Hillbilly
I couldn't find anything for flexplate on Napa's website, but here is one from Kragen's website that will work. Sold under the Pioneer brand, just standard quality.
http://kragen.com/ProductDetail.aspx...pe=267&PTSet=A Edit: just so you know, I have my home location plugged in on that link. Might want to change it to yours if you decide to buy off the website. Last edited by fryer1979; 08-20-2010 at 02:33 AM. |
08-20-2010, 11:47 AM | #11 |
Thanks again guys!
