Old 08-19-2010, 03:08 PM   #1
JimZ
JimZ's Avatar
Throttle-by-wire Pedal mounts
Anyone know of a manufacturer making mounts for these TBW gas pedals? This is an LS3 installation in a 65 2wd short bed. Or, if you have made one, can you send photos? Thanks.
JimZ is offline   Reply With Quote
Old 08-19-2010, 04:00 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Throttle-by-wire Pedal mounts
I want to know this also. Subscribed
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-19-2010, 06:47 PM   #3
Ackattack
Ackattack's Avatar
I just fabbed up a piece of metal with a couple of bolts through it and then welded it to the fire wall after checking all of the interferances.
Ackattack is offline   Reply With Quote
Old 08-19-2010, 07:47 PM   #4
TR65
TR65's Avatar
Here is how I did mine...
http://67-72chevytrucks.com/vboard/s...d.php?t=300335
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-20-2010, 10:01 AM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
This is a little different pedal than yours, but the concept is the same. On both of these I used the truck's original pedal.
This was the first attempt. I later found out they sent me the wrong pedal.
The correct one that is in the truck now:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-20-2010, 12:09 PM   #6
JimZ
JimZ's Avatar
Thanks to all of you for the responses, just what I was looking for. JimZ.
Old 08-30-2010, 08:25 PM   #7
soule64
soule64's Avatar
Here is how I did mine:
First, I removed the electronic stuff (potentiometer?)
Next, cut the pedal per 'glock'
Heated and straightened the lower portion of the pedal
Mocked and welded the two pieces back together
Reinstalled electronics and bolted to original position
Works like a champ!
soule64 is offline   Reply With Quote
Old 02-12-2011, 01:40 AM   #8
awhite4557
awhite4557's Avatar
I have a 71 chev PU and the donor vehicle was a 2001 GMC Suburban. I used the metal base for the factory pedal on the 71 and welded it to the back of the suburban pedal for added support. Then I drilled through the mounting holes on the 71 metal plate through the back of the mounting plate on the suburban pedal so that the holes lined up. I cut all of the pedal arm off of the suburban except for a few inches I would need to mount the 71 pedal arm to it. I then cut the 71 pedal arm and bent it to where it would be in the same position on the suburban base as it was on the 71 base and welded it to the short piece of arm on the suburban pedal. It worked perfect. The pedal bolted up to the factory holes on the 71. I used 1/4 allen head bolts to mount the pedal.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 02-12-2011, 11:51 PM   #9
67C10BUB
67C10BUB's Avatar
Post #121 on my build thread shows how I mounted mine. I just made a few plates out of steel, drilled holes for the new pedal mount and the stock pedal mount, and then welded them together. It seems a lot easier than what I have seen so far. It also gave me some adjustibility in the pedal position. My build thread is in my sig.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 02-16-2011, 01:53 PM   #10
JimZ
JimZ's Avatar
Nice truck! Thanks for sharing the info on pedal mount. I decided to start a blog for anyone that is interested in my build progress, but it's pretty incomplete right now. I'd rather work on the truck than the blog. Thanks.
http://my65short.blogspot.com/
Old 02-16-2011, 11:53 PM   #11
Hart_Rod
Hart_Rod's Avatar
Here's how I did mine:
Hart_Rod is offline   Reply With Quote
Old 02-17-2011, 02:06 AM   #12
JimZ
JimZ's Avatar
Thanks for the post - and the Proverb. I was just reading in II Chronicles this morning.
