Old 08-19-2010, 03:59 PM   #1
LandonL
LandonL's Avatar
Will I need to return this camshaft??
Today was going great, my new camshaft arrived and I opened it to find the bearing journals had a light rust on them. It's not terrible, but it's enough to concern me. I don't believe it's just surface rust, when I drug my fingernail across and there may be slight indentions. What should I do? Send it back? Is this going to damage the bearings or should it be fine? Here's a pic of one of the journals.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 08-19-2010, 04:01 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Will I need to return this camshaft??
Was this new from a vendor (like Summit or someone like that)? I would definitely send it back as you want those journals to be perfect or it's likely you could wipe out the cam, lifters or whole engine.
If it was previously owned by someone, even being new, you might be stuck with it but I would not run it.
My .02 worth.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-19-2010, 04:03 PM   #3
keenan
keenan's Avatar
mine had simmilar surfaces when i got mine. my father advised me to lightly use steel whool and see if itll clear it up. mine did but if urs still has indentions i would return it
keenan is offline   Reply With Quote
Old 08-19-2010, 04:04 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Send it back......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-19-2010, 04:05 PM   #5
LandonL
LandonL's Avatar
Got it from rockauto.
250 L6 .030 over
Old 08-19-2010, 04:18 PM   #6
71meangreenc10
Call them, they should be able to work it out, unless it was the last one they had on a closeout.
Smitty
71 C30 Wrecker
Old 08-19-2010, 04:26 PM   #7
LandonL
LandonL's Avatar
I shot them an email, I'll get around to calling them tommorow. In the case of it being surface rust and me not being able to tell, im gonna try and get it out
250 L6 .030 over
Old 08-19-2010, 04:31 PM   #8
71meangreenc10
Good luck....
Smitty
71 C30 Wrecker
Old 08-19-2010, 05:00 PM   #9
LandonL
LandonL's Avatar
Alright, took keenan's advice and used steel wool, it cleaned up pretty nice, there's no longer any catching when I drag my finger nail over it, it was probably just rust on top catching it. All thats left is like a blemish in the steel where the rust spots were. You guys think it's ok to use?
250 L6 .030 over
Old 08-19-2010, 06:27 PM   #10
treveiger
treveiger's Avatar
Its one of those things if it does wear out your bearing then you have to start all over and youll be kicking yourself for it later on. I would personally send it back, better safe then sorry right.
treveiger is offline   Reply With Quote
Old 08-19-2010, 06:35 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
X2, If I paid for a new cam and it looked like that I'd send it right back.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-19-2010, 06:49 PM   #12
LandonL
LandonL's Avatar
Called rockauto after I found a small chip in the very back journal. That did it for me, there sending me a brand new one plastic wrapped and well oiled so it doesn't rust like I requested. Should get it Monday.
250 L6 .030 over
Old 08-19-2010, 07:52 PM   #13
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
There is NO WAY I would use that in an engine. You are just asking for a bearing to get ate. And like someone said....you will have to tear the engine down pretty far to replace it.
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 08-20-2010, 12:01 AM   #14
mr48chev
mr48chev's Avatar
It looks like it has been sitting on the shelf for a long time or had been pulled out of the box and had the protective coating wiped off it and put back in the box. The chip in the lobe is the clincher though.
Old 08-20-2010, 12:13 AM   #15
tranz am
tranz am's Avatar
when it comes to engine parts, always play it safe!
that cam is garbage bro!
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 08-20-2010, 12:30 AM   #16
70cst
70cst's Avatar
Wise decision...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
