Old 08-19-2010, 04:40 PM   #1
SS Delux
SS Delux's Avatar
Drop shackles
Just wondering if anone has had any luck with the drop shackles and how hard they are to install ? Being from canada I know that the bolts are going to be rusted in pretty good, does anyone have suggestions on how to take them out without destroying anything?
SS Delux is offline   Reply With Quote
Old 08-19-2010, 05:01 PM   #2
TeXaS 86 C10
TeXaS 86 C10's Avatar
Re: Drop shackles
pre soak the bolts you are going to take off w/ some penetrating oil or wd40. id hit them up a few times a couple days before you are going to take them off
1986 LWB C-10 305/th400 Daily Driver and beer runner
TeXaS 86 C10 is offline   Reply With Quote
Old 08-19-2010, 05:36 PM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Drop shackles
If your bolts are as bad as mine were, don't even bother with the penetrating oil. My bolts were frozen to the steel sleeves in the bushings, so I had to cut off the bolt head on one side and the nut on the other with a cutoff wheel to get the stock shackles out. That's the only hard part though, smooth sailing after that!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 08-19-2010, 05:45 PM   #4
joe231
joe231's Avatar
Re: Drop shackles
CHEVY ONLY
